june 1,2008 rx8/rx7 Ne BBQ meet, LYndhurst N.J
if your not 1st your last
Hey guys
well you asked for it so we are putting this together.
funds are being collected this week on tuesday night @ local meet.exact location will be posted by either maverick or chrism which are local.
post away
post away
Misfit Moderator TnC
i was talking to klepto about this earlier....i think we should be doing this mid afternoon...just so we can have the most people and make it a bbq lunch deal....would any one be able to help him out with a midpipe install too?.....some one got ramps they can bring?
FYI - here is the location for the BBQ. For those of you not familiar with the area, we are probably going to have the staging point be at the Starbucks where we normally meet at and drive over to the bbq. Either Chris or I will scout it out this week to make sure everything is kosher for the weekend.
Here it is in relation to the starbucks:
Here are the two park spots. We will probably be using the north park.
on
thanks guys....looking forward to it this saturday. Chris I'll meet you and we can roll out I guess.
I got some stands and a jack and the oem 8 jack as well so getting it up in the air should be fine. Any help I can help is greatly appreciated. If anyone has a breaker bar I think that would be key.
Yes, this sunday
Here are a few of my tools if anyone needs to borrow them this Sunday
- Full 1/2" Metric set (short and deep)
- Full 3/8" Metric set (short and deep)
- Full 3/8" SAE set (deep only)
- Full 1/4" Metric set (short and some deep)
- Cordless Impact Wrench
- Full 1/2" Metric Impact Set
- 1/2" 18" breaker bar (with cheater bar for better leverage)
- Metric ratcheting wrenches (8, 10, 12, 14, 15, 18mm)
- Compression Gauge
- Remote Ignition Trigger
- 3 ton floor jack (not low model)
- 4 jack stands
- Rubber Mallet
Doubt they have electricity but also:
- Corded Dremel
- Corded Heat Gun
- Corded Soldering Set (+ wiring stuff)
- Corded Drill
- Compression Gauge
- 4 jack stands
- Rubber Mallet
- Corded Dremel
- Corded Heat Gun
- Corded Drill
i dont think he needs new gaskets ? fairly new vehicle with maybe a thousand miles
just get some pb blaster and the breaker bar will take care of the rest.
