Fuel Injector Info
Fuel Injector Info
I wanted to put all of this in one place for reference.
PRIMARY INJECTORS
RED 290cc
6-PORT SECONDARY INJECTORS & PRIMARY 2 INJECTORS
YELLOW 380cc
4-PORT SECONDARY INJECTORS
BLUE 480cc
Injectors are Bosh disc-type, high impedance (13 ohm) with a Denso connector.
PRIMARY INJECTORS
RED 290cc
YELLOW 380cc
BLUE 480cc
So I have a new engine in my car thanks to some water that hyrdolocked my old one... dont ask. Anyway, the fuel trim is off according to the mechanics. Well I asked someone at Mazsport, they said maybe the injectors were backwards. Any ideas? Im kind of confused seeing as it's two and four not three and three or something like that...
Chillgates (04-18-2022)
How it happened...
Well lets see. Here in Iowa, about a month back, we had a lot of rain coming down. Well one night my car and I went through this puddle of water. The AEM CAI decided that it would suck up the water instead of air, causing it to stall. Pushed it out of said puddle and let tried it. Nothing. Left it alone for a day to dry out and tried to turn it over. Nothing. Towed it to the only Mazda dealership in town, thinking they should know what they are doing. They said they took the plugs out and tried to turn the engine with a breaker bar and still couldn't get it to budge. So they replaced it. Then after I had it for a few days, the CEL comes on. I take it back, they say ignition coils. They pop new ones in and find that the fuel trim is off. Excessive as they say. A week later and I'm still car-less. Worse yet, they gave me a damn minivan. So please help in anyway possible. I asked a tech at Mazsport, they said maybe they got the injectors backwards, primary and secondary. From what I read, it might have been the MAF or O2 sensor. According to the techs though, they said they can test the MAF and found it to be OK. Now they want to replace my AEM CAI with the stock airbox. No thanks. Any ideas on how to keep my CAI and fix this fuel trim issue? Take it to a tuning place and reflash the ECU? I have no freaking idea...
Awfully nice of them. I presume this was under warranty?
Strike three!
They left your snorkel in the car, but gave you a free engine?
How, exactly, did they "test" the MAF?
What code did you throw?
Hey guys, I would like to announce that I am running my car with mazsport injectors with a stock ecu
I want to know whether it would damage the engine in anyway?
this is only temporary until i finish my turbo install ofcourse..
it does run like crap Jeff!!!, but I'll be out there to AZ mid august when Ray moves there so you guys can do your Uber magic on my car :D
however, I will be running there with *gasp* base tune
however, will it hurt my car though? in the long run I mean
