N3H1-18-100A-9U vs N3H1-18-100B-9U
Old 02-26-2009, 12:55 PM
rotaryPilot's Avatar
As the title implies
what is the difference ??? besides the letter
So you know that I am talking about Ignition coils
Old 02-26-2009, 02:45 PM
Super Moderator
ASH8's Avatar
The B is used in Series II RX-8's and at a chassis number Change on Series I, I believe from 2007....
HOWEVER, the parts now supersede to the B, so you can use B on ALL RX-8's, ..
What is the difference?, It is internally a better/longer lasting coil.
Old 02-26-2009, 03:09 PM
Its the same. Meaning they still dont last very long
Old 02-26-2009, 03:13 PM
Hmmmmmm.........
auzoom's Avatar
I cant recall exactly but is that a 3rd generation of the OEM coils? The switch to the 2nd generation was back in '05.
Cheers
Andrew
Old 02-26-2009, 08:52 PM
Super Moderator
ASH8's Avatar
Production Change Points for COILS
Remember this is for Australian Series I RX-8's, the parts are the same here as the US..
Old 02-26-2009, 09:07 PM
Super Moderator
ASH8's Avatar
N3H1-18-100 Superseded to an A at Chassis # Change JMOFE1031--104511, up to 2006 MY
N3H1-18-100A Superseded to a B at Chassis # Change JMOFE1031--105465, 2006 to 07 MY
N3H1-18-100B is still the current COILS used in production for Series II (09) RX-8's also and late Series I (2007-08 MY)
SO the new coils (B) fit all RX-8's, Mazda US have a locally sourced coils with a -9U on the end of the part number.
Old 05-15-2009, 03:10 PM
J-Rex's Avatar
How do I know which coils I have? I had to order off eBay because no dealer within 100 miles of me had more than 1 in stock, and they couldn't get any for at least 2 weeks... They look identical to the ones I pulled out of my '04 6spd, but they're only marked N3H1-18-100. A few lines down they also have "AIC-1279" "4X07"
Not really a pressing issue, I'm sure they'll work, just curious.
Old 05-15-2009, 03:43 PM
Mazmart's Avatar
I've sold the B before for the first generation cars. I don't recall a physical identifier other than the box had the new number on it. The A is still cheaper than the B and I don't know if there is improvement to the B.
Paul.
Old 05-15-2009, 07:52 PM
I keep getting the A version.
maybe next time I will get the B.
but if they superseded the part already I guess I will get a B next time no matter what.
Current coils have about 1K miles on them, brand new, A version. No more misfire. Lets see how long it would last before I see misfire.
Old 06-25-2009, 09:52 PM
Hubble has been saved!
msrecant's Avatar
My dealer put in two new coils today on my 2004. They were the B version.
Old 04-04-2010, 03:07 PM
Bigus Rotus
Nemesis8's Avatar
Smile Old Bump
I found some new OEM coils in my garage. They are part #N3H1-18-100A-9U. If nothing changed in the design of the coil as compared to the newer N3H1-18-100B-9U version, can I assume I could use them since they are brand spanking new?
Ash you mentioned it is internally a better/longer lasting coil, but also mention if related to a chassis VIN change. So what is the ultimate answer? Paul seems to think there is improvement to the B.
Old 02-23-2013, 02:14 PM
shoyurx's Avatar
Necro bump
Just curious if over the years anyone has noticed the difference yet. The A is still cheaper, so I'm leaning towards those if the B isn't an improvement.
Old 02-23-2013, 02:33 PM
j9fd3s's Avatar
as of today right now, Mazda USA has no A coils, and they have the same list as the B coils anyways, $80.29 each.
Old 02-23-2013, 03:06 PM
Glutton for punishment
McKennaR's Avatar
I've run A's, B's and Autozone replacements. Currently running B's. I see no difference in the butt dyno, no significant change in starts or fuel economy between these B's and the A's or the autozone reps.
There may be a difference but it isn't particularly noticeable. Replacing excessively worn coils with fresh ones, regardless of the P/N is going to be an improvement over what you had.
CPT Obvious signing off.
Old 02-23-2013, 03:14 PM
Charles Bundy
Grace_Excel's Avatar
Mazda OE Ignition Coils...Updated
Gbrldown
01-14-2015 01:28 PM
Reeko
36
07-18-2012 03:59 AM
seagram14
09-01-2010 07:18 AM
heyarnold69
NE RX-8 Forum
05-18-2009 12:28 AM
Quick Reply: N3H1-18-100A-9U vs N3H1-18-100B-9U
