Coolant Light comes on for 15seconds everyday..?
Old 09-24-2010, 08:31 AM
AlpineMica's Avatar
It seems that if I reach a higher than average rpm, even for a second, the coolant light comes on sometimes after then..generally it comes on just after i get onto the highway...the indicator then shuts off after about 10-20 seconds..?? coolant level is right where it should be. I checked both when engine was cold, and warm.. possible air in the lines..?? thanks!
Old 09-24-2010, 08:35 AM
terch1's Avatar
There are numerous threads that explain this. To keep it short and sweet, these sensors have a tendancy to crap out. The sensor is built into the reservoir itself and are rather expensive to replace. Over $300 if I remember correctly. You have 2 options a.) shell out the money for a new sensor or b.) do as most of us have and learn to live with it.
Old 09-24-2010, 09:03 AM
AlpineMica's Avatar
In that case, I will live with it..as long as know there wasnt anything wrong with the actual cooling system. thank you
Old 09-24-2010, 09:46 AM
Khaf's Avatar
Well I think if you decide to live with it you should check your coolant more often, like every fill up. Just in case if you have a leak and sensor is faulty.
Old 09-24-2010, 11:05 AM
the giant tastetickles
yiksing's Avatar
Yeah its the sensor, i tried bleeding out the air but still get it as long as i'm above 5k+ rpm for more than 10 seconds. Annoying as hell, gonna get some real water temperature gauge and unplug the sensor in the future.
Old 09-24-2010, 01:15 PM
ken-x8's Avatar
Checking the coolant level is very easy...translucent tank, right up front, nothing obstructing your view.
During my first four years of ownership, my light came on a handfull of times at the customary high rpm condition. Most of the events were in the week before and the week after my B to B expired, causing the expected "Do I rush to the dealer to get it fixed for free?" and "Damn! I missed the freebie" anxiety.
Since then it will come on randomly once every few weeks. It's likely to do it while just driving along at steady speed and modest rpm, which is different from most people's experience.
Not often eough to bother me, and the light itself is kind of cute. Looks like either a Rolls Royce radiator or a Greek temple. If a passenger happens to notice it, I tell them it means we need to stop for a gyro.
Ken
Old 09-24-2010, 01:22 PM
Surf Hard, Drive Hard
Mazurfer's Avatar
Unplug it and check level on your own!
And if really bored out of your skull..............here's my thread on the subject!
https://www.rx8club.com/series-i-trouble-shooting-95/coolant-bottle-greatest-secrets-revealed-182793/
For the sake of argument, I did in fact get a new bottle "rev M", but I also monitor my water temp(not level) real time.
Attached Thumbnails Coolant Light comes on for 15seconds everyday..?-coolant_sensor_locale.jpg   Coolant Light comes on for 15seconds everyday..?-coolant_mark.jpg
Old 10-08-2010, 06:23 PM
05rotary's Avatar
hepl me on this!!!!
i have the same issue with the sensor, i had read a bunch about it (yea, its the sensor), but i need to know why is it that the coolant still coming out through the little hose of the tank. when i checked the coolant its low, so i filled it up to about full line, so no overfilling, right? why is the coolant keeping coming out? before didn't do that....
thanks....
Old 10-10-2010, 06:50 PM
Super Moderator
ASH8's Avatar
New Coolant tank with sensor is not $300..
N3H1-15-350M Coolant Tank $163.58 USD from Montgomery's
Old 10-10-2010, 06:53 PM
Super Moderator
ASH8's Avatar
thanks....
Could be a number of things, from Tank Pressure Cap (and sealing), leaking Rad Hose, to the worse of Coolant Entry into Engine (hard starting usually occurs).
Take it to a Radiator specialist and ask for a System Pressure TEST, to find ANY external Leaks first...and take it from there.
Old 10-11-2010, 01:16 PM
Rudolph's Avatar
EU
Hi ASH8,
Is N3H1-15-350M the latest version?
In Germany this nr. was used by guaranteereplacement, however since short, with malfunction this item is changed having the item nr. N3H1-15-351G.
Best regards, Ruud
Old 10-11-2010, 02:39 PM
Super Moderator
ASH8's Avatar
N3H1-15-350M is the latest version.
Old 10-12-2010, 03:05 AM
Rudolph's Avatar
EU
Thanks..........
Best regards, Ruud
02-27-2020 08:39 AM
Azki23
06-27-2018 03:48 PM
erikcamacho15
09-12-2015 11:23 AM
Irvinb16
09-11-2015 10:27 PM
Quick Reply: Coolant Light comes on for 15seconds everyday..?
