{ FS } Hinson LSX V8 swap kit brand new
Old 06-19-2014, 02:52 PM
turboholic's Avatar
FL SOLD. Hinson LSX V8 swap kit brand new (price reduced)
Category: Drivetrain
Price: $2800
It took me almost a year but I finally received the complete Hinson V8 swap kit. It took so long that I went a different route with my setup. I paid right at $5,000 for the kit shipped. I'm willing to let it go for $4600 shipped and you will have practically zero wait time to get your project started. The kit comes with all the extras you need including the tach kit and long tube headers.
Here is what comes with the kit:
HSC RX8 LSX Mounting Equipment Kit
HSC RX8 Long Tube Headers Stainless Steel, 1.875, 3' Collectors with integrated merge spike
HSC RX8 Radiator/Cooling System - Single Fan
HSC RX8 Steel Driveshaft
HSC RX8 V8 Master Cylinder (Modified)
Banjo Bolt, Banjo Fitting, & Washers
HSC New SS Clutch Line LS1
HSC RX8 Sway Bar Mounts
MGW FBody Short Throw Shifter - 12mm x 1.75' Handle
HSC RX8 Stainless Steel 3" Ypipe (allows you to connect long tubes to stock exhaust)
HSC RX8 Tach Kit - Includes Machined Balancer, CPS Bracket, and balancer bolt
Kit is located in Tampa,FL.
Contact Dan at 719-291-6388
******Update. Sold the Long tube headers and Y pipe. New price is $2800 obo. plus $150 for shipping.
Old 06-22-2014, 06:59 AM
turboholic's Avatar
I can take $1500 off the price if someone wants the kit without the long tubes and y pipe.
Can take $500 off the price if the tach kit is not wanted.
Thanks.
Old 06-27-2014, 03:40 PM
turboholic's Avatar
Here are more details on what is included in the mounting kit:
Urethane Engine Mounts
Billet CNC Engine Stands
New Tie Rod Ends
Steering Adapter
Steering Rack Mounts
Transmission Brace and weld on mount plates
Torque Arm (Differential Support) & Mount
price is obo. thanks guys
Old 07-16-2014, 03:37 PM
turboholic's Avatar
Lots of interest in the kit so far. No takers yet.
Old 08-18-2014, 05:08 PM
turboholic's Avatar
buyer has backed out. this is back up for sale. thanks.
Old 08-27-2014, 06:51 PM
turboholic's Avatar
Sold the Long tube headers and Y pipe. New price for everything else is $2950 shipped. obo.
Old 08-27-2014, 11:53 PM
turboholic's Avatar
As per a request here is the price for each item from my hinson invoice.
$1185 HSC RX8 LSX Mounting Equipment Kit
$565 HSC RX8 Radiator/Cooling System - Single Fan
$275 HSC RX8 Steel Driveshaft
$95 HSC RX8 V8 Master Cylinder (Modified)
$13 Banjo Bolt, Banjo Fitting, & Washers
$87 HSC New SS Clutch Line LS1
$150 HSC RX8 Sway Bar Mounts
$235 MGW FBody Short Throw Shifter - 12mm x 1.75' Handle
$491 HSC RX8 Tach Kit - Includes Machined Balancer, CPS Bracket, and balancer bolt
Total is just under $3100.
Old 10-30-2014, 02:46 PM
turboholic's Avatar
Everything is sold. Thanks
Blackbriar2189
Non-Rotary Swaps
786
02-04-2019 09:04 PM
Brokegang
01-03-2016 12:45 PM
TFWorks
Non-Rotary Swaps
106
07-25-2014 09:35 AM
SEANMAC777
10-30-2013 10:41 AM
Quick Reply: { FS } Hinson LSX V8 swap kit brand new
