Greddy install build-Adaptronic
Old 12-07-2015, 12:14 PM
  #76
Lucky #33
hoss -05's Avatar
Nice, looking forward to it.
Old 12-22-2015, 08:16 PM
  #77
yurcivicsux's Avatar
8psi with stock ignition. 231 hp, 185 ft/lbs
Old 12-22-2015, 10:26 PM
  #78
Has anyone with a stock 8 ever ran on the dyno that you have results from? That's pretty low. well, really low actually.
Old 12-22-2015, 10:35 PM
  #79
Agreed those numbers seem low. No offense but that seemed to take for.e.ver to wind up. Don't take it the wrong way, just surprised that was an 8 psi pull. The flames were fun though. Keep at it!
Old 12-22-2015, 11:02 PM
  #80
Hybrid Greddy Boosted
JimmyBlack's Avatar
If you've still got a catalytic converter I recommend taking it out if that's an option. Removal really helps spool up and is much healthier for a turbo application. If you do this watch your boost levels after the de-cat as they'll be much higher than they were before.
Old 12-22-2015, 11:05 PM
  #81
yes i think so around 175hp but i would have to verify with thewird he is the guy doing the tuning and the dyno pulls. also i only posted that as an update for the thread. after waiting so long it was good to see it at least running. we encountered some issues which resulted in the lower numbers we see, and will re-post over the winter.
Old 12-22-2015, 11:17 PM
  #82
Good update! It is satisfying to see it running after you've spent a lot of time on it. Keep going, I'm excited to see more!!!
Old 12-23-2015, 09:33 AM
  #83
Oh okay, well that explains it.
Old 12-23-2015, 10:45 AM
  #84
it's a gutted cat so shouldn't be an issue i would think.
Old 12-23-2015, 12:53 PM
  #85
what sort of issues did you have?
Old 12-23-2015, 06:34 PM
  #86
El Jefe
yomomspimp06's Avatar
#savage
I really shouldn't fuel the fire...I just like to instigate
Old 12-24-2015, 09:37 PM
  #87
when we finally hit the dyno we lost compression on front bank during a power pull, the motor now needs a rebuild. Thewird thinks it was a piece of carbon that came loose. was hoping to get a year before rebuild.... guess not. the video wouldn't have been the final pull
Old 12-25-2015, 10:14 AM
  #88
Piece of carbon that came loose? Oh Boy. Good luck. You should send us your tune to have a look at. My guess is that it was a tuning issue, not a carbon issue.
Old 12-25-2015, 11:24 AM
  #89
could be i'm not sure..... i'm at the mercy of what i'm told
Old 03-04-2016, 08:35 PM
  #90
Sakebomb ignition and ATP wastegate
Old 03-23-2016, 04:00 PM
  #91
Okay so spring is here and the build is making some progress including a full engine rebuild and tune by thewird
-machined ground plates
-2 new/used housings 40,000km
-2 new/ used rotors 40,000km --EDM wire modified for the larger RX7 apex seals
-RXtuning and performance apex seals
-oil porting mods
-exedy stage 1 clutch
-new ATP wastegate
-Sakebomb coils (AEM marine coils)
-upgraded BNR water cooled turbo
-water/ meth injection?
Can’t wait to get it back…………..
Last edited by yurcivicsux; 05-30-2016 at 11:59 AM. Reason: http://www.rx8club.com/editpost.php?do=editpost&p=4752207
Old 03-23-2016, 04:03 PM
  #92
Old 03-23-2016, 04:13 PM
  #93
-oil porting mods
Can you elaborate on this please ?
Also , make sure you get solid corner seals (without the recess)
Old 03-23-2016, 05:07 PM
  #94
ATP/SARX wastegate I'm glad it will benefit the community, it was a bitch to get done.
On my Pineapple engine he did a porting an clean up of all the oil galleys and he removes the plugs cleans inside the galley in the eshaft, and installs new plugs. In addition to the different regulator.
Old 03-23-2016, 05:53 PM
  #95
thanks... we'll see the greddy wastegate proved to be junk, didn't hold boost well.
considering upgrading the turbo to BNR while were at it, the issue is simply cost (exchange rate to CDN) as i have already dumped so much $$ into this already and haven't even drove it at 8 psi. .....as speed is relative the power i get may be just fin for what i want.
Question;
is it so difficult to install the BNR turbo at a later time or should i have it all done now while the engine is out and save my back next year? i have been told the BNR would get me up into the low 300 mark....
i feel like i would be more than happy for the next years with what i have focusing on reliability and the complete package than simply more power.
thoughts?
Old 03-23-2016, 06:07 PM
  #96
no it doesn't ... but there is a reason for that . Upgrading the WG fixes the boost problem which is ok for streeting it , but i sure wouldn't be wanting to run a stock greddy on the track at elevated boost.
Old 03-24-2016, 05:37 PM
  #97
SPOOLN8
RotaryMachineRx's Avatar
Question;
thoughts?
My ATP actuator just showed up too. Was getting a boost leak through my stock GReddy actuator that wasn't showing up until around 9psi. Will be swapping that out as soon as the snow is gone.
As far as the BNR upgrade goes, if it is at all feasible for you to bite the bullet and pay for it now you'll be thankful for it later down the road. Although some might argue that pulling the turbo isn't ridiculously hard; keep in mind that most people find this to be the most difficult/time consuming aspect of getting the kit installed. I'd say 65% or more of my install time was spent down there.... Of course it all depends on your mechanical abilities and how many times you've done it before (that was my first time installing it and my first major car project). I believe I need to pull my turbo to swap in the new ATP actuator but I'm hoping to get away with just popping the turbo off the manifold and gaining enough room through the wheel well without having to pull the turbo/manifold out altogether.
Old 03-25-2016, 10:21 AM
  #98
driftengoku's Avatar
Hello
I am new to the forum
I installed a greedy kit in my rx-8 was all perfect
I installed a new programmable injection FuelTech
the car is everything perfect however this leaking oil through the rear seal
I changed it for the second time and I think that with a lot of pressure on the bottom
Should I make a bigger breath
anyone ever had this problem?
it only leaks oil at high RPM
thank you
Old 03-25-2016, 10:54 AM
  #99
yes i agree installing the turbo was challenging especially on my back under the car in my small garage. good luck with the wastegate...... not fun.
going to hold off on the BNR for now...... who knows what i will do in a few years. love the idea of it. the exchange rate should come back down in a few years also, right now it's .66 which is a lot as you know.
Old 03-25-2016, 12:16 PM
  #100
SPOOLN8
Yeah I did the install under similar circumstances..... I wan't thinking about exhange rate in my previous post. It's ridiculous.
Also small edit to my last post..... boost leak was WASN'T showing up until 9psi.
Quick Reply: Greddy install build-Adaptronic
