Greddy install build-Adaptronic
Old 06-03-2016, 08:11 AM
  #126
fastrax203's Avatar
Originally Posted by RotaryMachineRx
DO NOT use the E-Manage.... I highly recommend the Cobb for price vs simplicity to use (that's what I use on my stock Greddy kit running 9psi with EBC). You just need to find someone to tune it for you unless you are learning on your own.
My kit is stock and my engine has at least 50k on it. Compression was solid though. I just picked up a Cobb AP but it won't connect with the AP Manager. I'm running windows 10 and apparently I have to use a pre windows 8.1 machine to update the AP so it will work with Windows 8.1+...?
Old 06-03-2016, 01:49 PM
  #127
Yes you need windows or you need to do a work around like running a virtual machine, there is a thread about it here that dives in to it. I just bought a cheap old laptop with win 7 on it and use it only for tuning.
Old 06-03-2016, 01:54 PM
  #128
fastrax203's Avatar
I have an old Netbook that I used to use for tuning my Megasquirt PNP on my Miata with but it won't charge anymore
Old 06-06-2016, 10:15 AM
  #129
SPOOLN8
RotaryMachineRx's Avatar
I also just have an old laptop with windows 7 that gets used strictly for my COBB.
Old 06-13-2016, 11:32 AM
  #130
yurcivicsux's Avatar
motor is built, home stretch now
love that colour combo
Old 06-15-2016, 03:27 PM
  #131
Old 06-29-2016, 07:17 AM
  #132
Old 06-29-2016, 09:52 PM
  #133
Looks good. Still running the air pump?
Old 06-30-2016, 10:03 AM
  #134
ya because i have a gutted cat therefore we already have one not ready fault on the ecu which i believe is overrode by the adaptronic for emissions testing, + i want everything to remain 'looking' emission compliant. we have DOT police here checking for those types of things.
does nothing anyway
edit; not running the air pump but the hose is installed so it looks like it, needed room for the meth pump.
Old 07-01-2016, 10:28 AM
  #135
weeeeeeeeee
ShellDude's Avatar
does nothing anyway
adaptronic overrides nothing in regards to readiness. It can (optionally) clear all CELs but this does nothing to address emissions readiness testing.
Old 07-04-2016, 08:51 AM
  #136
yes......okay thanks for clarifying that makes more sense now....i already have one for not ready which you can get away with as a conditional pass, but you will not pass with 2 'not ready's'.
because i have no cat i get a CEL, thankfully the adaptronic over rides the CEL. (i think the not ready and the CEL are both from having no cat)
Old 07-07-2016, 09:28 AM
  #137
It can clear the CEL but from my understanding it cannot block them like the Cobb can.
Old 07-08-2016, 08:24 PM
  #138
Old 07-08-2016, 08:29 PM
  #139
El Jefe
yomomspimp06's Avatar
doublepost
Old 07-08-2016, 08:32 PM
  #140
El Jefe
who is tuning?
and I just saw an old video of your car from last year
Old 07-08-2016, 09:17 PM
  #141
tuning by thewird, have to break the engine in first.
Old 07-09-2016, 07:58 AM
  #142
some minor engine clean ups and color changes on the way.
On the original build I was limited to a few factors such as a stock motor, stock ignition, 6psi with a slight boost leak, stock plugs,small exhaust leak on the turbo flange , and low compression on the front bank (chipped apex seal near the corner) the car made around 231 hp on the dyno in the previous video. Moving forward with the freshly build motor with RX-7 seals,BNR turbo, new waste gate, exedy clutch, AEM marine coils, meth injection, vibrant couplers, T-bolts I’m hopeful to easily pass the 300 mark.
I have to do a break in period on the motor first, the new turbo spools fast and can easily reach 5 psi around 3,500 rpm if you’re on it. Before the final tune on meth I have to investin a 3” mid pipe and cat back. Right now I’m on a gutted cat and 2.5 stainless exhaust which would have been just enough for the original set up; which was my original intention..... but as you can see we all know how these projects go$$$....
We have used the windshield washer tank as the reservoir for the meth for additional capacity, and should be able to hit 14-16 psi on the final tune, with race plugs and a new fuel pump. One decision I have to make it whether I want to tune on water/meth or straight meth.
Old 07-09-2016, 11:37 AM
  #143
El Jefe
Which plugs are race plugs?
What are your plans for the vehicle? In all honesty though, I think your fueling setup/turbo setup won't really warrant the use of full meth. I vote 50/50.
Old 07-09-2016, 10:23 PM
  #144
colder plugs, i'm using stock plugs right now for the break in. and yes i'm also leaning more towards 50/50 on the meth. n
Need to sort out this CEL issue for emissions test and find a 3" exhaust.
Old 07-10-2016, 12:13 AM
  #145
. One decision I have to make it whether I want to tune on water/meth or straight meth. [/COLOR][/SIZE][/FONT]
There is a very good reason why people don't use 100% meth ....................
Old 07-10-2016, 03:00 AM
  #146
El Jefe
^actually people do use 100% meth....
I'm using 100% meth on my speed6 build. Auxiliary fueling. Bigger injectors aren't available for that particular direct injection application. big meth nozzles at the throttle body providing enough fuel to push 500+awhp when stock fueling only supports roughly 350awhp...
Old 07-10-2016, 03:59 AM
  #147
Out of the windscreen washer bottle next to the engine ?
Old 07-10-2016, 09:49 AM
  #148
Old 07-10-2016, 11:19 PM
  #149
El Jefe
not in the windscreen bottle, but in the engine bay. Dangerous? yes, but I live my life a quarter mile at a time.
Old 07-11-2016, 02:17 AM
  #150
I like your spirit. Just be careful. I had an engine bay fire because of a leaky catch can and that was scary enough....
Quick Reply: Greddy install build-Adaptronic
