slash128's Top Mount Build
Old 06-20-2016, 10:57 PM
  #1776
See what happens when I get banned. I blame the tuner.
Old 06-20-2016, 11:16 PM
  #1777
Originally Posted by yomomspimp06
spill the beans! I'm not a very patient man
Picked up a running donor from a wrecked car for pretty low cost. I'll take the best bits from both to build the new motor. Will be getting the rotors machined for E&J rx7 apex seals and also will be using E&J solid corner seals. Will be adding WI as well. This thing should be as bullet proof as possible for a Renesis
Old 06-20-2016, 11:18 PM
  #1778
I blame myself as well. I had actually thought to myself (prior to losing the motor) that I should have extended my maps beyond 250% since I knew I was bumping up close. But 254% load on a stock motor, tell me who else is pushin' that. I like to experiment and sometimes it comes with a price. But I pay to play
What'd you get banned for?!?
Old 06-20-2016, 11:52 PM
  #1779
E&J huh...... Yeah man, when you push it you have to accept the consequences. I like that you're not a bitch and enjoy the process. It's refreshing and in short supply here in for sure. But you and some others have plans in the works that are promising.
Old 06-21-2016, 12:53 AM
  #1780
El Jefe
yomomspimp06's Avatar
he didn't choose the thug life. The thug life chose him
Old 06-22-2016, 04:09 PM
  #1781
Took the kids for a ride today. Dropped off to wire EDM the apex slots. 1 rx7 rotor sample, 1 dented Renesis rotor for test cut and 2 good Renesis rotors for the final build.
Old 06-22-2016, 05:06 PM
  #1782
Make sure you use solid corner seals with no recess !
Old 06-22-2016, 05:39 PM
  #1783
Affirmative. E&J apex and solid corners!
Old 06-23-2016, 03:01 PM
  #1784
Has anyone ever called in on a reman tag? I've heard you can get information like when it was sold. The used motor I picked up had a reman tag and was curious about its age. It came out of a t-boned car but the inside looks pretty fresh. Hardly any carbon and what was there came off quite easily. The housings and irons look great as well.
Old 06-23-2016, 03:06 PM
  #1785
El Jefe
don't solid corners eat plates?
Old 06-23-2016, 03:13 PM
  #1786
I don't think they have that info at the dealer or Mazda NA. The reman plant probably does but I doubt they will release the details.
Yes.
Old 06-23-2016, 03:21 PM
  #1787
I've read mixed results but for me the goal is surviving what would otherwise be catastrophic detonation on OEM apex and corner seals, not so much expecting 100K miles out of it. I haven't even hit 100K miles in the 10 years I've owned the car since buying it new, but I've blown two motors now
Thanks for the info.
Old 06-23-2016, 05:47 PM
  #1788
El Jefe
haha that's one more than me!
I just feel like with good tuning(you can do it!!), I would rather pay for new corners and seals than add plates to the cost of a rebuild as well. I are cheap
Old 06-23-2016, 06:00 PM
  #1789
The E&J apex and corner seals are not made of steel so they are supposedly not nearly as hard on the irons as steel solids. Also they weigh less than other solids made of steel.
Old 06-23-2016, 06:03 PM
  #1790
The only issues I've heard of with solid coners are when the ones with recesses are used (like the ones Aitkens sells) It makes sense really as you need all the surface area you can get when they run over the exhaust ports.
Old 06-23-2016, 06:05 PM
  #1791
enj-auto-works
enj-auto-works
Old 06-23-2016, 06:20 PM
  #1792
El Jefe
and just to clarify because I don't want to go back and check i.e. lazy. you're going to machine for rx7 apex seals?
Old 06-23-2016, 06:40 PM
  #1793
Yes lazy, you even 'liked' my taking the kids for a ride post when I dropped them off for EDM
Old 06-23-2016, 06:41 PM
  #1794
haha .... pwnd
Old 06-23-2016, 07:11 PM
  #1795
El Jefe
I happen to like everything you say slash. #mancrush
Old 06-23-2016, 07:20 PM
  #1796
Well I can find no fault in that
Old 06-23-2016, 07:56 PM
  #1797
Red line envy's Avatar
First timer rebuild. Any suggestions on a seal kit. 04 rx8
Progress so far
Old 06-23-2016, 07:58 PM
  #1798
I've got a special source for my stuff that unfortunately I can't share. Maybe some of the others have suggestions?
Old 06-23-2016, 08:03 PM
  #1799
Not a problem. Any tips for me. Lol im a carpenter not a machanic so anything helps. So far ive taken the engine out myself and labled things as best i could and took note haha.
Old 06-23-2016, 08:09 PM
  #1800
There are some rotary rebuild videos that are a great start. I believe Mazdatrix and Atkins both have one. The factory engine manual is good to have too. I would recommend you find a local rotary guy or gal to help you out. There are a lot of nuances to these things I'll be posting as I go so hopefully that might help you as well.
