Old 06-30-2016, 06:18 PM
  #2676
New Yorker's Avatar
Originally Posted by keitan
It took me three times to finally do it, but I finally re-homed my RX-8 after shopping for a proper buyer. After getting my 4Runner...
So sorry to hear. My thoughts are with you and your family.
New Yorker is offline
Old 07-01-2016, 09:15 AM
  #2677
Red line envy's Avatar
Plan to do today
Get engine stand (fingers crossed)
Get front cover and its contents removed.
Then really stuck on that big 54mm.
Any members in saint john nb have a socket and a min to crack this for me ?
Red line envy is offline
Old 07-01-2016, 11:54 PM
  #2678
mendozad80's Avatar
Gauges
Originally Posted by BigCajun
That's a nice set. Did you have to buy everything separately for that, or can you get the whole set?
your set up looks nice... where did you get the wires? do you happen to have a part number?
did you use auto meter 2252 for the water and oil temp sender? and 2242 for the oil pressure sender? can you use digital gauges with your set up? do your gauges light up red at night?
i just bought the adapters from good-win racing and need to get the rest of the parts.
Thanks for your help.
Daniel
mendozad80 is offline
Old 07-02-2016, 09:09 AM
  #2679
Did you get the front hub bolt off? It's harder than the flywheel nut and you'll want it off before you remove the flywheel. There is a tool (Mazdatrix has them, along with the big sockets) that locks the flywheel so you can remove the front hub boot without the crank spinning.
https://www.mazdatrix.com/toolmisc.htm
slash128 is offline
Old 07-02-2016, 10:46 AM
  #2680
I didnt get the engine on the stand yet it needed some tweaking. And i have a chain holding flywheel still while i get the hub bolt off. I cant get the hub bolt off untill its on the stand. Because i cant crank on it hard enough when its on the bench lol its just gonna fall. And i dont need that.
Old 07-02-2016, 12:19 PM
  #2681
6 rotors....I want more!
jaimesix's Avatar
Hi.
Working on my RX8. I was thinking about painting the black section of my rear bumper (07) red, like rest of car.
Four possibilities :
1) Leave it as it is, stock format.
2) Paint red only the side edges, where the exhaust pipes exit, leaving the center section black.
3) All red (matching car color) except only for the fake mesh grill at center of black section, giving impression of having a real mesh in there ( real mesh would probably be a muffler vent.
4) All of the black section (from exhaust pipe edges through all center area, all) painted to match car.
I think it might look better all in matching color.
Wish I knew Photoshop so I could try it virtually.
jaimesix is offline
Old 07-02-2016, 12:27 PM
  #2682
jaimesix's Avatar
Got these pixes from internet. Top is a stock bumper. That is the section I was talking about.
By painting edges an effect similar to the white car's aftermarket bumper would be achieved.
What ya think guys !
jaimesix is offline
Old 07-02-2016, 08:53 PM
  #2683
reni04's Avatar
Just finished the 2 core aluminum radiator swap and took it for a drive and happy to say no leaks. The aluminum radiator left substantial gaps round all side / top and bottom. I solved this using foam pipe insulators ( 1.5 inches in diameter with the split glued ends. It sealed the radiator on all sides, Happy camper !!. Next is the starter. The original starter is a poor 1.4 or 1.8 KW slow starter.
reni04 is offline
Old 07-03-2016, 02:00 PM
  #2684
jaimesix's Avatar
I do not want to use aftermarket bumpers because the quality is inferior to stock plastic.
Seen aftermarket ones and those crack and fail miserable upon minor things like regular "parking" contact.
I would change all the black section of the stock bumper for a red colored plane part. Those fake vent meshes are only that, fake mesh on the stock bumpers.
Yes, will do something like this. This is the look I favor using stock bumper !
jaimesix is offline
Old 07-04-2016, 06:05 AM
  #2685
motohegg's Avatar
Ordered 17x9 Enkei RPF1 wheels and 245/40 BFG G-force Rival S tires for track/autocross duty.
motohegg is offline
Old 07-04-2016, 08:40 AM
  #2686
Pug 205 & RX8 Lover
Pugheaven's Avatar
What bumper is this? That is gorgeous!!!
Pugheaven is offline
Old 07-05-2016, 06:26 AM
  #2687
lowen12's Avatar
Changed my spark plugs and detailed the engine bay.
lowen12 is offline
Old 07-05-2016, 07:56 AM
  #2688
Changed the oil, replaced the trans and diff oils, bled the brakes, changed the spark plugs, straightened the oil cooler fins some more, adjusted the radiator foam, lubed the sway bar bushings.
Steve Dallas is offline
Old 07-07-2016, 02:09 AM
  #2689
Jastreb's Avatar
Picked her up from a professional detailing. She hasn't looked this good since I got her!
Jastreb is offline
Old 07-07-2016, 04:15 PM
  #2690
n00b
carrrnuttt's Avatar
I echo this question. That is the only aftermarket bumper I'd consider putting on my R3 right now, but I'd like to research it and see how it looks from the side.
carrrnuttt is offline
Old 07-08-2016, 12:24 PM
  #2691
Unruly Newb
Gravey's Avatar
Here's a link on this site to an owner with the kit:
Photoshoot by Matrx8 | RX8Club.com
https://www.rx8club.com/g/album/2958512
Gravey is offline
Old 07-08-2016, 08:13 PM
  #2692
Did some cleanin while im waiting for socket
Old 07-09-2016, 08:40 AM
  #2693
1% evil, 99% hot gas.
wankelbolt's Avatar
Holy **** did the Exxon Valdez run aground in your engine bay?
wankelbolt is offline
Old 07-09-2016, 02:06 PM
  #2694
jaimesix's Avatar
What happened ????
Is this a Mazda RX3 engine found at the bottom of Lock Ness Lake ????
jaimesix is offline
Old 07-09-2016, 09:22 PM
  #2695
tigg.z's Avatar
Received and installed my afe short shifter today after wanting one for a long while. Next is cleaning up all the gunk around that area and fixing the broken ashtray lid...
tigg.z is offline
Old 07-10-2016, 06:37 PM
  #2696
Not sure what original cause was. It has been greasy under there since i bought it. Obviously and oil leak to start but it was literally everywhere. So it cant be pin pointed. Doing a full rebuild anyways 😄
Old 07-14-2016, 08:18 PM
  #2697
Hootyhoo's Avatar
I took a nice long drive down a river road and when i got home there was a couple packages waiting on me on the porch. I just received my cooling fan kit and a box from BHR with new Ignition System and catless midpipe.
So after the car cooled down enough to install the cooling kit, I got it installed and tested. So far the temp hasn't went above 193F.
Its was too hot outside to be under the car today, so i didn't get the other stuff that came today on it.
Then i dove it to the gas station and filled her up. I thought about just going back home but she begged me to go out for another cruise to check out temps while treating her how she likes it. It never broke 200F but before the install i was hitting 215-220.
Looks like Saturday is going to be somewhat nice out, so I might be able to do everything else i need to do. (midpipe, Ignition System, overflow bottle replacement, block airflow around radiator, screens for oil radiators and straighten the fins, screen for A/C and straighten fins) Soooo much to do and so little time
Hootyhoo is offline
Old 07-17-2016, 01:33 AM
  #2698
dafiltafish's Avatar
Compression Test
240 or 300 rpm... not sure really
87-88-86 rear
90-90-90 front
Altitude: 1800 feet
Unsure of what to do next.
dafiltafish is offline
Old 07-17-2016, 11:41 AM
  #2699
Charles Bundy
Grace_Excel's Avatar
This is what someone did to my RX-8 three days ago!
I was entering a lane out of an alley while the traffic was at a stop. Crept up to the far left turn lane so I can exit the intersection while this guy in his Camry just decided to cut traffic to get on the same lane and slam on to me. The traffic was at a complete stop, I don't know why the ****'s there a need to go 20-30 miles an hour to get on a lane where he'll eventually be at a stop?
I've had some bumper to bumper in the past but this is the only major one this car has had the whole time I've owned the RX-8.
I would have driven it further home until I noticed the oil leak form a cracked oil cooler.
Grace_Excel is offline
Old 07-17-2016, 12:34 PM
  #2700
wankelbolt's Avatar
Originally Posted by dafiltafish
Compression Test
87-88-86 rear
90-90-90 front
Altitude: 1800 feet
I know what to do. Drive the **** out of it. She's fine.
My compression is high-60's, low-70's and I still can run rings around M3's. It just doesn't seem to matter on the RENESIS except it's harder to start. 2KW starter is a must.
