Brettus turbo 111 (the ultimate Renesis turbo ?)
Old 07-18-2016, 09:58 PM
  #1026
Hybrid Greddy Boosted
JimmyBlack's Avatar
I did a preliminary test and there's barely any change from previous turbo. I want to get the boost pressure profile to match a bit more closely with previous results before I post a comparison. It's been pretty hectic, but this is definitely still on the to-do list.
Old 07-22-2016, 11:53 AM
  #1027
Out with the old , in with the new :
Approximations For reference:
For every 1mm of compressor inducer diameter - 100rpm slower spool
For each step in turbine AR (0.63 to 0.82) - 250rpm slower spoll
Single scroll vs twin scroll - 500rpm slower spool
My manifold twinscroll vs single - approx. 300rpm
Old 07-22-2016, 12:48 PM
  #1028
Received 2,703 Likes on 1,946 Posts
Brettus always has all the fun toys.
Old 07-22-2016, 01:05 PM
  #1029
El Jefe
yomomspimp06's Avatar
which wheels are those?
Old 07-22-2016, 05:48 PM
  #1030
Bottom is the GT3582 wheel that came with the turbo . Top is a GTX3576 copy that I bought off ebay .
My frankenturbo will now have Garrett housings , Kinugawa turbine, Onehunglo bearings and Mambatek compressor.
Old 07-22-2016, 05:51 PM
  #1031
If only ......... I have a handbrake that prevents such things.
Old 07-22-2016, 06:06 PM
  #1032
JimmyBlack's Avatar
GTX yo! Looking forward to seeing whether this changes performance much.
Old 07-22-2016, 06:36 PM
  #1033
me too ...fingers crossed !
Old 07-24-2016, 11:58 PM
  #1034
So we are up and running again .
The good news :
*more power right through the rev range (due to going back to 1.01AR ) . Losing traction again in 2nd now.
*Pulled 460g/s .....highest i've ever seen !
*exhaust actually sounds better .... lost most of that pulsing it had when the 2nd stage kicked in.
The bad :
spoolup is freakin identical !!!! FFS WTF !!!!!Borrowing Jimmy's parrot here ...............
Before anyone says it's due to the larger AR turbine housing . Spool was the same as this with old wheel and 1.01 as well .
I'm thinking it's a housing clearance issue . This wheel had much larger clearances than the other one .
Old 07-25-2016, 12:02 AM
  #1035
Link doesn't work.
Old 07-25-2016, 12:18 AM
  #1036
Originally Posted by 9krpmrx8
Link doesn't work.
fixed ...i'm sure you've seen it already though....
Old 07-25-2016, 02:55 PM
  #1037
Clearance is around 0.8mm which seems like too much to me . The old wheel was 0.45mm which seems normal.
Old 07-26-2016, 12:21 AM
  #1038
accidentally deleted turbine backpressure data .... Bugger !
Old 07-26-2016, 02:16 AM
  #1039
El Jefe
looking good
Old 07-26-2016, 08:04 PM
  #1040
TomD_Cincy's Avatar
So I have zero experience with turbos but I do work in aerospace and most of the compressor aero guys I work with would sell their souls to get clearances .35 mm tighter. Granted that's on engines for commercial aircraft. But unless it needs the more open clearance to keep the wheel from rubbing the housing, seems like some performance is being left on the table.
Old 07-26-2016, 08:59 PM
  #1041
Agree 100% . I actually emailed the suppliers and they told me they allow extra clearance on non standard covers to be on the safe side. So I wont be doing it that way again !
Old 07-26-2016, 09:04 PM
  #1042
sinkas's Avatar
Yeh that seems like a lot of clearance for a compressor
Old 07-26-2016, 09:41 PM
  #1043
Gunna try this turbo next . Should see huge improvements !
Old 07-26-2016, 10:53 PM
  #1044
El Jefe
^ looks like it moves some air lol
Old 07-26-2016, 10:58 PM
  #1045
I'm excited about having no bearing losses !
Old 07-26-2016, 10:59 PM
  #1046
Go Brettus Go!!!
Old 07-27-2016, 04:34 PM
  #1047
After upgrading the injectors to blue/uncapped yellow/uncapped yellow and switching to E50 , I have now run out of fuel again at 460g/s .
Happily this is about the limit of the turbo and the modified maf setup as well so probably wont be taking it any higher than this.
Old 07-27-2016, 04:53 PM
  #1048
Dark Moderator
Williard's Avatar
Zoom Zoom, No boom! WOO!
Travis
Old 07-27-2016, 08:08 PM
  #1049
El Jefe
throw up a VD so I can look on in amazement
Old 07-27-2016, 10:11 PM
  #1050
Running out of places to do a 3rd gear log ..... here is one in 2nd . Doesn't seem that wonderful ....but I've never seen such a good result in 2nd before.
Quick Reply: Brettus turbo 111 (the ultimate Renesis turbo ?)
