slash128's Top Mount Build
Old 07-25-2016, 05:42 PM
  #1976
It runs! Just had to push it doen my hill about 100 feet Much frustration about nuthin' Thanks for all the encouragement! Here's Fazda with the victory shot
Old 07-25-2016, 05:44 PM
  #1977
madrotor's Avatar
Hopefully everything breaks in nicely and you'll get some real good compression numbers mate! !! Very excited for you
Old 07-25-2016, 05:51 PM
  #1978
Dark Moderator
Williard's Avatar
Hooray for Slash!
Time for a gentle break in
Travis
Old 07-25-2016, 06:48 PM
  #1979
Nice work man, does it start hot and idle? Now replace that coolant reservoir.
Old 07-25-2016, 07:54 PM
  #1980
WOOT !!!!!! Great to hear !
Old 07-25-2016, 08:28 PM
  #1981
Thx guys! I dorked up the rear gear o-ring and have an oil leak but otherwise all good! Gonna drop the trans and fix that next...
Old 07-25-2016, 08:41 PM
  #1982
Thx to Fazda for coming out to help!!!
Old 07-25-2016, 08:57 PM
  #1983
It does hot start and idle! Though still just a tad hard starting. But I think my starter is pretty tired. It's the original and I really worked the last few days... the overflow tank is on my want list
Old 07-25-2016, 09:05 PM
  #1984
Well that's good. And yeah I saw that 230RPM crank on the compression tester and figured your starter was not doing well. Get an S2 starter, it will blow you away.
https://www.amazon.com/Mitsubishi-St...9+Rx-8+starter
Old 07-25-2016, 09:25 PM
  #1985
FazdaRX_8's Avatar
glad I could come out and get it started!!
Old 07-25-2016, 09:31 PM
  #1986
FazdaRX_8's Avatar
thats the starter I was talking about, remember like you said its like the starter is holding it back.
Old 07-26-2016, 12:13 AM
  #1987
madrotor's Avatar
Yes that S2 starter makes a world of difference for tired engines let alone for freshly rebuilt ones.
On a side note
Brettus changed his avatar pic hehe
Old 07-26-2016, 12:30 AM
  #1988
Thank so for the link, I'll check it out!!!
Old 07-26-2016, 12:34 AM
  #1989
I got the trans back out tonight. I'll pull the rear stationary gear tomorrow and fix that o-ring...
Old 07-26-2016, 09:36 AM
  #1990
Ordered that starter, should be here tomorrow. I needed some Red Line for the trans anyway
The guy that loaned me the comp tester asked if I did the test with throttle wide open. I had not, my first time, whoops. He said not doing this would make the numbers low. We plan to retest at some point.
Old 07-26-2016, 10:33 AM
  #1991
Former Sponsor
RX-Tuner's Avatar
Fantastic Slash! Glad to hear it just needed a bit more rpm to light off, congrats!
Old 07-26-2016, 10:59 AM
  #1992
Thx man!
Old 07-26-2016, 11:05 AM
  #1993
When you hold the pedal down it cuts fuel but I am not sure if the throttle plate is wide open or not. I tested that tester along with our rotary diagnostics one and the Mazda factory one and all three were pretty close. We used the factory method for testing.
Old 07-26-2016, 10:45 PM
  #1994
Fixed the seal and all back together. Just waiting on the Red Line MT-90 and starter, which I should have in the morning.
For anyone reading this and attempting a rebuild here was my fatal flaw with the oil leak. Silly me, when I took apart the motor the o-ring came off with the rear gear. Looking at the rear gear there is somewhat of a groove at the base, so I assumed this is where the seal goes:
Wrong It wasn't until we saw the leak that I pulled out another rear iron and gear to figure it out that I saw the groove in the iron:
I actually just found this on Mazdatrix website:
"* If using the RX8 rear gear in an earlier 13b engine, you must add sealant where the rear gear o-ring WOULD be. There is no groove to hold the o-ring because the Renesis engine mounts the o-ring in the side housing rather than on the gear. We recommend using Hylomar, but a THIN layer of silicone sealant will also suffice."
Old 07-26-2016, 10:58 PM
  #1995
Thanks for sharing. That starter is going to blow your mind.
Old 07-26-2016, 11:13 PM
  #1996
Groovy man !
Old 07-27-2016, 04:48 AM
  #1997
Red line envy's Avatar
Just want to say ive been following quietly and well done. Im takin my time on my build studying and reading up on specs because its my first time. Wish me luck.
Old 07-27-2016, 08:13 AM
  #1998
Thx man! This was my first rebuild as well. Good luck to you!
Old 07-27-2016, 02:10 PM
  #1999
Sicker than your average
Nisaja's Avatar
Pretty cool build. Just wanted to chime in on the starter... A cranking speed of 230RPM is bad? My car is a 2012 with the upgraded starter and it cranks at 180RPM
Old 07-27-2016, 02:28 PM
  #2000
Don't you have an auto? We only speak manual here. I have an S2 starter in my 04' and it cranks between 290-300RPM. Several others local have it as well and the results are similar, some even over 300RPM. The standard minimum for a compression test is 250RPM.
