slash128's Top Mount Build
Old 08-08-2016, 03:18 PM
  #2076
Originally Posted by Williard
How's the break in Slash?
Travis
Just got back to the airport and warmed up the car. Still only 259.6 miles since I've been out of town but consistency pulling good vac:
Old 08-08-2016, 03:41 PM
  #2077
Break in, Shmake in, turn that bitch up.
Old 08-08-2016, 03:46 PM
  #2078
at least let me get thru my 500 mile oil change
Old 08-08-2016, 04:21 PM
  #2079
BigBadChris look what showed up while I was gone, thx man!
Old 08-08-2016, 07:48 PM
  #2080
BigBadChris's Avatar
I found it on my desk at work under all my keys. I don't know how and why I brought it to work....
Happy to help out.
Old 08-08-2016, 09:35 PM
  #2081
El Jefe
yomomspimp06's Avatar
QFT
Old 08-11-2016, 08:36 PM
  #2082
Old 08-11-2016, 09:20 PM
  #2083
Does this mean what I think it means ?
Old 08-11-2016, 10:03 PM
  #2084
No time like the present, as they say...
Old 08-11-2016, 10:08 PM
  #2085
El Jefe
~9 psi isn't enough, but it's a start *devil on your shoulder*
Old 08-11-2016, 10:42 PM
  #2086
4psi
Old 08-11-2016, 11:23 PM
  #2087
Originally Posted by slash128
4psi
green for GO !
Old 08-11-2016, 11:47 PM
  #2088
Black...and don't go Back
Old 08-11-2016, 11:52 PM
  #2089
Black and blue ........might put him in the poo
Old 08-12-2016, 12:44 AM
  #2090
El Jefe
I'm colorblind... I thought it was blue at first glance
Old 08-12-2016, 07:47 AM
  #2091
working up to it...
Old 08-12-2016, 04:16 PM
  #2092
FazdaRX_8's Avatar
exciting!!
Old 08-12-2016, 04:33 PM
  #2093
I've got the WI starting at 2psi to see what it would do. So far can't tell it's spraying other than the light. I know juice comes out because I can blow into the sensor hose and watch it spray. I wasn't expecting to notice anything but figured I'd sanity check
Old 08-12-2016, 07:17 PM
  #2094
El Jefe
those AITs should be dropping. i hate we dont have the temp sesnor in the most desirable spot
Old 08-12-2016, 08:00 PM
  #2095
Tru dat.
Old 08-13-2016, 10:44 AM
  #2096
I'm thinking winter project build...
Old 08-13-2016, 11:10 AM
  #2097
Just finished changing the oil and finally found the source of my slow drip. It is coming from the clutch slave hose. I wiped everything down and watched and over a period of a minute or so a drop would form on the outside of the hose, seeping thru the steel braid. I'm pretty sure this is due to me letting the trans down a little to far when I was putting the motor in because it was fine prior. At least it's a relatively easy fix.
EDIT: while the clutch slave hose does have a very slight drip (replacement en route) the real culprit was finally found. I missed an oil pan bolt amazing how much one bolt will leak. Cleaned up the hole, added some RTV and a bold and no more oil drips
Old 08-18-2016, 09:19 PM
  #2098
Question about closed loop targets: the Cobb help file says "The values in the table are a percentage of the main Air/Fuel table target values." What I interpret here is if the main A/F target is 14.7 and the CL table has 1.10 then 14.7 x 1.10 = 16.17, or if the CL value is 0.90 then 14.7 x 0.90 = 13.23, is that what you guys come up with? I have played with this a bit over the years but not completely convinced it is working as documented. Not that the Cobb help file has been infallible
Old 08-18-2016, 09:26 PM
  #2099
Nope ... it's actually the exact opposite of that .
Old 08-18-2016, 09:30 PM
  #2100
That's what I've been suspecting, thx!
