slash128's Top Mount Build
Old 09-01-2016, 06:42 PM
  #2151
I got nothin' to prove If Brettus hits 500RWHP I will be very happy!
Third gear log...
Old 09-01-2016, 10:35 PM
  #2152
A little more tweaking... That 3rd gear log was weak. This is still second here and starting to look a bit more promising...
Here's an overlay of the progression from the last three modifications I have made:
Old 09-02-2016, 12:46 AM
  #2153
Where did the big gain come from ?
Old 09-02-2016, 04:47 AM
  #2154
El Jefe
yomomspimp06's Avatar
and what is this tweaking you speak of?
Old 09-02-2016, 10:21 AM
  #2155
I leaned it out some between 5K and 6.5K. Oh, and I added the MBC Just making sure you guys are paying attention
In all seriousness though, JB got me thinking (thanks JB!) and looking at past logs and he is correct that my previous logs at 12psi last September were better than my current logs at 13psi. I used to spin the tires in 2'nd at 12psi, but not now at 13... Looking at the load curve and seeing it hit sooner I realized I had the MBC in back then, but adding it in still didn't get the tires spinning, even with a couple more psi's... I also did a pressure test, just to be sure, and found no leaks...
I'm still figuring out tuning with WI. I have it running really rich. From what I gather a properly sized nozzle will drop AFR by about 0.5 with no other changes. So where I was targeting 10.8 with no WI I started targeting 10.3. Since the stock O2 only goes down to 10.9 I have to watch the dash gauge and make some guesses. I know the dash gauge drops down in the low 10's but it is hard to keep it all straight and correlate with RPM by memory. Wish I had a (feasible) way of logging my gauge. But regardless, also from what I gather a properly sized nozzle should yield slightly higher power with no other changes, just by cooling the intake charge.
I am still working on it, but perhaps it is my motor build. It was my first ever rebuild, so maybe I didn't get it quite right.
Here is an overlay comparison. All 2'nd gear. The red and blue lines are from last September at 12psi, tires broke loose pretty early. Now the green line at 13psi (actually hitting a little higher based on the load, but I was focusing on AFR gauge, not boost) I have traction all the way through to red line.
Old 09-02-2016, 02:58 PM
  #2156
Ok, not foolin' here
I keep slowly leaning it out and it is getting better. This is back to no boost controller, where previous high was 252. If I can bring up the region from 5500-6500 I think I will be back in the realm I used to be in...
Anyone play with this table? Not sure what it will do.... My guess is it will add fuel where specified higher than 0.00????
Old 09-03-2016, 11:29 AM
  #2157
Latest progress. Comparison between last two modifications. This is all just from steadily leaning it out. Still need in the 5500-6500 range. All at 13psi, no MBC...
This is the progression over the last 4 modifications:
Old 09-03-2016, 01:38 PM
  #2158
El Jefe
how are your plugs looking?
Old 09-03-2016, 02:10 PM
  #2159
Oooo good question. I'll have to pull them soon to see...
Old 09-03-2016, 02:23 PM
  #2160
Looks to me like you have APV coming on too late for 2nd ...
Old 09-03-2016, 02:30 PM
  #2161
El Jefe
I agree.
That graph does look extra wavey
Old 09-03-2016, 02:44 PM
  #2162
I'll try playing with the APV open RPM...
Old 09-03-2016, 02:57 PM
  #2163
In M/E there are two maps for the APV .I have never actually experimented with the second map to see what it's doing but I suspect it's for 1st or 2nd or both. The cobb maps only have 1 ...will be interested to see if you can adjust for second gear ............
The (2nd gear 16psi) log below was taken with settings of APVB- 5750 and APV-5900
Old 09-03-2016, 03:07 PM
  #2164
El Jefe
it's going to be interesting seeing the lean spot move to a lower rpm.
Old 09-03-2016, 03:18 PM
  #2165
I'll give it a go and see what I get...
Old 09-03-2016, 03:22 PM
  #2166
Maybe I should quit letting second gear logs take the **** out of me and just get on with third gear already
Old 09-03-2016, 03:24 PM
  #2167
3rd gear logs are definitely more reliable ..... But it does look like you could get some big gains in 2nd just by playing with APV opening.
I'm doing 100mph at 8000rpm in 3rd with my 5 spd gearbox
Old 09-03-2016, 03:29 PM
  #2168
El Jefe
3rd is good but 4th is better...
Old 09-03-2016, 03:34 PM
  #2169
I'll save 4'th for the dyno
  #2170
El Jefe
I'm always stirring the pot
Old 09-03-2016, 04:04 PM
  #2171
I've noticed that If I get my APV perfect for street logs , it all goes to **** on the dyno because the dyno ramp rate never matches reality .
Old 09-03-2016, 05:19 PM
  #2172
I set the APV open RPM to 5750 but it didn't seem to change when it actually opens. I also leaned things out a tad more, and it seems to be trending in the right direction. Wish I could adjust the APV for 2'nd cuz it looks like when it does open it really let's loose, and I can feel it too! Though I am suspect I am starting to loose traction at APV open, which is why it is spiking so sharply...
Old 09-03-2016, 05:51 PM
  #2173
Damn ! looks like you need M/E to adjust apv in 2nd
Old 09-03-2016, 06:04 PM
  #2174
Yeah.... at least I'm seeing what I used to see. Glad JB reminded me. I'm no longer questioning my rebuild
Old 09-03-2016, 06:47 PM
  #2175
You'll find 5750 is a little too soon for third BTW
