Alignment settings for street/track use
Rating: Thread Rating: 4 votes, 5.00 average.
Old 07-05-2016, 03:48 AM
  #476
mrbarry76's Avatar
Thanks, yes I have them already but I need the lowers too so my question still stands.
Old 10-31-2016, 06:01 PM
  #477
ybyrx8's Avatar
Road Racing, -1.7F -1.0R 0toe all around
Old 03-02-2017, 08:47 AM
  #478
Nadrealista's Avatar
so has anyone used whiteline camber kit bushings to get more negative camber out of stock suspension?
what is the trick to get most negative front camber out of the stock suspension?
Old 03-02-2017, 09:17 AM
  #479
I have not personally tried it. I did ask Chris at Cobb Tuning, who does a lot of performance suspension work, about offset bushings in general, and he told me they have trouble with them moving and not holding an alignment. His recommendation is adjustable control arms.
Counterpoint...
I asked Terry at Vorschlag Motorsports (also does a lot of suspension work) the same question, and he said they have used them successfully in many cars.
That was quite literally of no help, wasn't it?
I will be at the track Saturday and will try to remember to ask the owner of Motorsport Enterprises (specializes in Miatas and RX-7s and 8s) what he thinks of them.
It would be great if they work. The most negative camber I have been able to get out of my front suspension is -2.4. That is with a ride height of 3.75" measured at the pinch welds. I want -3.5. Badly.
Old 03-02-2017, 10:00 AM
  #480
These are my current settings, BTW. The front is uneven, but I told him to "max out both sides, and I will drive to it." Turning left and turning right are a little different.
Old 03-02-2017, 10:33 AM
  #481
Suck it up and get the Speedsource lower control arm camber bushings
You won't have any trouble getting -3.5 with a lot more caster than that too
Old 03-02-2017, 01:21 PM
  #482
mrbarry76's Avatar
Thats great. If I could buy them.
Everywhere I have asked says NLA
I guess I'll have to make my own - a pain but at least I can make them with slightly more offset.
James
Old 03-02-2017, 01:24 PM
  #483
mrbarry76's Avatar
I recently put a set in. If they "turn" you are doing it wrong. Works just fine, but like you, I need more total neg.
James
Old 03-02-2017, 03:18 PM
  #484
Did you try Mazdaspeed Motorsports? They used to have them
Drop used to make them as well...but I think that they stopped making them a few years ago
Old 03-02-2017, 03:41 PM
  #485
mrbarry76's Avatar
Drop = NLA
Mazdaspeed only allow membership if within US or race annually in US.
I'm in AUS
Old 03-02-2017, 03:53 PM
  #486
Originally Posted by mrbarry76
Drop = NLA
I'm in AUS
Might not hurt to ask around if someone can get you a set
Or call Speedsource directly and see if they sill make them
Old 03-02-2017, 04:13 PM
  #487
mrbarry76's Avatar
Yes I've been doing that for a year.
I might just do that but my hopes are low.
Old 03-03-2017, 07:46 AM
  #488
Mazdaspeed Motorsports lists the following part:
0000-04-5420
BUSH.KIT,OFFSET(DELRIN)
Notes: BUSH.KIT,OFFSET(DELRIN)
MX-5 Miata
RX-8
ALL
2004 - 2015
$86.80
No idea who makes it, or if it is for one axle or two.
Old 03-03-2017, 04:29 PM
  #489
mrbarry76's Avatar
0000-04-5420
MX-5 Miata
RX-8
ALL
2004 - 2015
$86.80
they are just the offset UCA bushes like shown in post #478
the part # we are after is 0000-04-8001
Old 03-03-2017, 06:08 PM
  #490
MSM site says NLA.
Old 03-04-2017, 04:51 PM
  #491
mrbarry76's Avatar
MSM site says NLA.
indeed it does
Old 04-06-2017, 01:07 PM
  #492
blu3dragon's Avatar
Thanks for posting. Makes me feel a bit better about my new car's alignment. Was at -2.7 on the front right, but could not get more than -2.3 on the left. Ended up evening it out so -2.3 all around (front and rear).
This is with -6 caster and a ride height around 13.5in from hub center to wheel arch. I'll need to check what that equates to from the pinch welds, but it is not super low.
Backing out the caster did not make much difference to the static camber btw, so I think I will add more in next time.
My prev car was at -2.9 at the front, but slightly lower, so probably equivalent to -2.7 at this car's ride height.
0.15 degrees toe seems high in the rear? I never really know what to have here, am at 0.05 per side right now, and 0.00 at the front.
Old 04-06-2017, 01:57 PM
  #493
Yes, I think that amount of rear toe is a little high. I let them talk me into it, when I was troubleshooting my Ohlins oversteer issues. Next time I take it in, I plan to have it backed down to around where yours is.
Old 04-08-2017, 08:38 PM
  #494
Here's basically what the lower control arm camber offset bushings look like.....these are the Drop Engineering ones...but they look the same as the Mazda speed ones
Has anyone tried contacting Speed source directly?
Old 04-09-2017, 07:13 PM
  #495
mrbarry76's Avatar
Yep.
No response.
Old 04-09-2017, 08:08 PM
  #496
Yep.
No response.
That sucks....
If I thought that there was a market for them they likely wouldn't take much to make.
Old 04-14-2017, 02:00 AM
  #497
Zoom-Freakin'-Zoom
swoope's Avatar
That sucks....
and they add how much? you in south fla? willis?
Old 04-14-2017, 04:24 AM
  #498
You can get a about 2 deg more - camber than stock.
​​​No..about as far away as you can get in lower 48 😎 and then about 10 miles north 😎
Willis? Like Bruce? 😉
I will be in Mid Florida in a couple weeks of you want to buy me a beer 😎
Old 04-14-2017, 12:44 PM
  #499
Would I be able to get away with just getting the lower control arm kit, or do I need to get both?
I am guessing lower would yield most additional negative camber with leaving the UCA stock?
More importantly do these stay put - don't rotate during the track use?
Has anyone actually used them?
interesting install video:
Old 04-14-2017, 01:32 PM
  #500
pcs
pcs's Avatar
fwiw, I went to a local shop out in LA that handles a lot of tracked / raced miatas, and they tried to use offset bushings to get some additional camber adjustment, and they had tons of issues with them (in general, not these specifically). They would rotate while being tracked... and when they drilled and bolted them in, they cracked. They basically said they weren't a viable solution, as sometimes the camber would get out of adjustment after a single session...
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: Alignment settings for street/track use
