Crazy idea to Protect your CATs, when CATsare required
Old 11-01-2017, 03:23 PM
***** Stalker since 2006
derkenblosh's Avatar
I just had a crazy idea !
Figured out a way to make it possible to run a STANDARD (cheap) cat on a track / street platform, be able to stay clean for the environment (for those who care), and kinda/sorta be in regulation for tracks/events that require a cat....
a thermal controlled bypass! to control the Cat bypass,
All it would take is a circuit to monitor a thermocouple, and to open a mac valve when the cat was too hot, the mac valve would lead to a vacuum (or boost ... if you're not NA) actuated exhaust bypass flap with a checkvalve (so it could close itself) ... basically the same way boost is regulated. temperature of the cat could easily be regulated. Would cost about $100-140 in parts, so a complete system could be sold for about $250-$350 more than a standard/custom catalytic converter setup!
I was going to do something similar to my diesel, but not to protect anything... I just wanted to control when my car rolls coal on a tailgater
lots of coffee in me, so if this doesn't make sense, shoot me :-p
... I no longer have an 8, just can't afford to own a toy right now...
Old 11-01-2017, 04:56 PM
Old 11-01-2017, 05:45 PM
Received 2,040 Likes on 1,663 Posts
Old 11-04-2017, 11:05 PM
tgaffner's Avatar
