NA SemiPP 20b
Old 05-25-2017, 10:04 AM
Gold Wheels FTW
reddozen's Avatar
Hopefully I'll have some more substantial updates in the next couple months. Car is at the body shop and engine is with the builder.
Old 06-30-2017, 09:01 AM
Gold Wheels FTW
reddozen's Avatar
Spirit R headlights are in!
Old 08-11-2017, 01:52 PM
spent so much money
Killawatts's Avatar
Can't wait to see how this turns out, might go the na route myself
Old 08-14-2017, 09:04 AM
Gold Wheels FTW
reddozen's Avatar
PROMAZ crossmember on it's way. Thanks for finding this Team. Saved me a lot of time and money in the long run.
Xcessive Engineering short LIM with Full Function Engineering fuel rail and 6 ID1050 injectors arrived.
Old 12-03-2017, 02:15 PM
Gold Wheels FTW
reddozen's Avatar
Just a couple updates. Pineapple Racing 1pc solid dowel, and Goopy Performance 17pc 10mm stud kit. I think the irons are with Mazmart getting lapped.
Also for some new wheels. Volk SF Challenge 19x10.5 for the rear and 19x 9.5 for the front.
Federighi (05-15-2019)
Old 12-03-2017, 05:00 PM
Received 2,044 Likes on 1,666 Posts
Staggered and 19”? Must be 2fer phail day ...
Old 12-04-2017, 10:11 AM
Gold Wheels FTW
reddozen's Avatar
Street car so don't care. This car will likely never see the track, and if i does, it would be with dedicated wheels and tires for that purpose. This car has had staggered 19's on it for almost 10 years.
Old 12-04-2017, 12:33 PM
blackmount's Avatar
Should have told me you had a build thread.
Subbed... I like the Seats personally... They remind me of alot of the cool factory seats you find in the 90's out of japan... I think Nissan and Honda had some of the best patterns... I like the color too.
This will be good reference if I pull the trigger on a 3 Rotor build or not...
reddozen (12-04-2017)
Old 12-04-2017, 06:00 PM
Given the cost of 19” tires you should care a lot. Stagger prevents you from properly rotating tires fore-aft.
Old 12-04-2017, 07:16 PM
blackmount's Avatar
As someone who frequently runs properly wide, both staggered and squared wheel setups on their cars... My experience is the staggered setups have the best road manners - Op specified this was as street car, so naturally that is what you want. As far as 19's go Large Diameter wheels also tend to ride better since they "fall" into large cracks and small potholes less.
I wouldn't run 19's either, but there are good reasons for doing it, and it will look good.
Old 12-04-2017, 09:35 PM
Gold Wheels FTW
reddozen's Avatar
If I can afford a 20b, $500 - $1,000 a year in tires isn't much of a concern to me. At least the car wont be "Stanced"...
LeftyTheNub (12-05-2017)
Old 12-12-2017, 09:04 PM
Nick_20B's Avatar
A 19" rim is too large of diameter is what I think they are getting at, however, I could be wrong. 19" is like a show car rim
Maybe I missed it, as I am going to be doing the same thing here in the near future with my newly acquired 8, what is the purpose of your build?
Thanks,
Nick
Old 12-13-2017, 03:44 AM
They don’t fall in less unless the tire OD is increased, which tends to be an issue with any lowering on an RX8 especially when going wider too. Generally speaking they’re heavier with shorter sidewalls and more likely to take pothole damage. If you want road manners go buy a Lexus rather than stick a 20B in an RX8 chassis, but that actually might make sense. If that’s what he wants it’s not necessary for you to make lame arguements on his behalf because what he wants on his car is all that matters.
Old 12-13-2017, 10:07 AM
Gold Wheels FTW
reddozen's Avatar
Thanks,
Nick
19's are stock on 09+ cars. The argument is basically staggered vs square, and overall weight. Team isn't wrong on that fact that my setup isn't ideal performance wise. It's just ascetics. It's also not a track car.
Old 12-19-2017, 01:57 AM
Narrow 19”, and I was against that too.
Still looking forward to seeing you get ‘er done!
Let me know if you need a pair of Panspeed rear flares
Old 12-19-2017, 04:40 PM
Gold Wheels FTW
reddozen's Avatar
Actually, I have panspeed front and rear fenders already. They will be widened a little extra though, and the front will be modified for S2 lights.
Old 12-19-2017, 05:00 PM
Sounds good, just realized that it was someone else that had asked me.
Old 12-28-2017, 06:10 PM
Nick_20B's Avatar
Where'd you source those spirit r headlights? I need something cool like that for my 2004 LOL
Old 12-29-2017, 03:19 PM
Gold Wheels FTW
reddozen's Avatar
Mazmart. They're not chep, and you'll need the adapter harnesses, all the mounting brackets, and an S2 09+ front end swap.
Old 12-29-2017, 05:10 PM
19" Volks FTW. Love the SF', my buddy has almost the same specs on his 8.
Old 12-29-2017, 07:29 PM
Have to admit that looks sweet!
Old 12-29-2017, 11:44 PM
Nick_20B's Avatar
Noted... what mounts you using for 20b fitment? I fit the 13bre with fd rear crossmember kit and defined 20b to fd mounts.
Old 01-01-2018, 12:28 PM
Gold Wheels FTW
reddozen's Avatar
ProMaz in Australia has a universal subframe they've made.
Old 02-21-2018, 02:20 PM
  #49
itsboost's Avatar
this is what i think a 20b should be used for.
Old 12-06-2018, 05:23 PM
Gold Wheels FTW
reddozen's Avatar
Thought I'd give an update since it's been a while.
With the S2 swap the Panspeed fenders will require too much work to match with the S2 lights and to widen them. I have gone with the Lions Kit V2.
The eshaft is out of alignment, and the kink is too close to a lobe to be straightened. Per Rick Engman the motor will have an 8500 RPM redline, max do to the shaft issues, but should be fine otherwise. This makes the original NA build pointless, as to reach the power goals, we would need to spin it higher.
Rotors are back from Chip Motorsports. Lightened, balanced, and side clearanced. Image attached.
An adapter kit has just been released for the 370z JK40C transmission to bolt to rotary engines, so I'm going that route for the transmission as it should hold a LOT more power than any of the RX8 solutions at a reasonable price.
For anyone interested in the transmission adapter: JK40C/CD009 Transmission from 370Z on 13B
The motor has been large street ported, and it will also have a small half bridge instead of the semi pports.The setup is changing to a single turbo, and vmount setup. It's scheduled to go into the fabricator March 3rd to have the turbo plumbed and for a little "Hammer Time" on the tunnel for the new transmission. Hopefully I'll have everything else ready before the fabricator, so once he's done, it can go straight off for tuning. Going to try and have it ready for DGRR 2019... We'll see how that goes...
Anyone interested in a set of Panspeed wide fenders, and EvoR carbon fender vents?
Also have a 5spd transmission I wont be needing...
The following 2 users liked this post by reddozen:
200.mph (12-06-2018), strokercharged95gt (12-06-2018)
Quick Reply: NA SemiPP 20b
