Odeur d'essence dans mon huile
Old 08-26-2018, 07:41 PM
Tomy de Chevigny's Avatar
Bonsoir à tous ,
depuis une semaine j'ai de l'essence qui s infiltre dans mon huile ,j'ai fait 2 changement d huile en une semaine et j'ai toujours une odeur d'essence dans mon huile.
Quelqu'un a déjà eu se problèmes ou pourrais savoir quelle est la cause ?
merci d'avance pour votre aide .
Old 08-26-2018, 09:18 PM
You will need to translate to English if you want help here.
Old 08-26-2018, 09:52 PM
Smell of gasoline in my oil
Smell of gasoline in my oil !!
Good evening everyone,
For a week I have gasoline that seeps into my engine. I made 2 oil changes in one week and I still smell gasoline in my engine.
Has anyone ever had problems or knows what is the cause?
Thank you in advance for your help.
Old 08-26-2018, 10:00 PM
If the seals on the side of your rotors are worn , gas can leak passed them from the combustion chamber . If this was happening it is likely your compression will be low also .
Tomy de Chevigny (08-26-2018)
Old 08-26-2018, 10:13 PM
I had a expensive compression test mazda 2 weeks ago.
the test ranged from 70 to 75 psi on each side of the rotors and mazda ma said the test was good.
I find it very low compression
Old 08-26-2018, 10:16 PM
sorry the translation is not perfect
Old 08-27-2018, 12:15 AM
75psi sounds very low but it depends on cranking speed .
Tomy de Chevigny (08-27-2018)
Old 08-27-2018, 04:45 AM
I will inform the dealer about the startup speed because it is not indicated on my invoice.
Thanks for your help .
Old 08-27-2018, 05:16 PM
vous êtes les bienvenus
Rxxne237
07-05-2016 07:27 PM
USMC_RX8
06-14-2011 06:12 PM
tomfdr88
RX-8 Discussion
11
05-21-2008 10:00 AM
DARKMAZ8
10-16-2005 12:06 PM
Quick Reply: Odeur d'essence dans mon huile
