{ FS } Rx8 13brew swap part out
Category: Engine - Power Adders
Price: $5999
Location (US State/Canada/Int): KY
- Mount setup -
Rx8performance motor mount kit
Modified Rx8 oil pan
Modified Rx8 front cover
- Turbo setup -
Thick wall stainless steel manifold, fully divided runners
Twin 46mm Precision wastegates
Garrett Gt42 turbo
5" to 4" stainless steel downpipe with vband and wideband bung
4" stainless steel midpipe with vband, Large Vibrant stainless resonator and Vibrant 4" stainless flex section
Aluminum intercooler piping
Large bar and plate intercooler
Greddy R bov
Braided AN turbo oil feed line
Braided AN turbo oil drain line
Couplers / tbolt clamps etc
AN boost reference lines
Electronic boost controller with adapters
- Cooling system -
Large Koyo radiator with custom mount bracket
Mishimoto aluminum fan shroud with dual fans
Custom aluminum coolant lines
Silicone couplers
Custom rx8 thermostat housing with AN fitting welded on for heater core line
Custom heater core lines
Modified Rx8 ac compressor with custom ac lines
- Haltech Standalone ECU - $1200
Haltech PS1000 with long wire loom terminated for a 13b rew engine / Haltech fuse and relay block built in
- 13brew engine shortblock - $3999
8k miles never boosted over 3 psi
Full Bridgeport
8.5 compression rotors with 3mm apexseals
Rx8 e shaft
Dowel pinned
Oil mods
Balanced
I have decided on a 3 rotor for the drift car now so i will no longer need the custom intake / haltech ecu / injectors so im willing to sell the entire swap including the custom intake manifold / RMR throttle body / ID injectors / Haltech PS 1000 ecu with fuse and relay wire harness etc..
COMPLETE turn key kit. Bolt in and have tuned.
If SERIOUSLY interested and would like to make an offer please message me.
Thanks !
Thanks !
TTT
Price drops!
REW swap kit - $8500
- Mount setup -
- Turbo setup -
Garrett Gt42 turbo
Greddy R bov
- Cooling system -
Silicone couplers
- 13brew engine shortblock - $4750
Full Bridgeport
Rx8 e shaft
Dowel pinned
Oil mods
Balanced
Price drops!
- Mount setup -
- Turbo setup -
Garrett Gt42 turbo
Greddy R bov
- Cooling system -
Silicone couplers
Full Bridgeport
Rx8 e shaft
Dowel pinned
Oil mods
Balanced
comebackqid (12-08-2017)
SilverHokie
RX-8 Multimedia/Photo Gallery
05-04-2009 08:28 PM
