{ FS } Manual, 2005, 2 owners, runs very strong
Manual, 2005, 2 owners, runs very strong, PRICE DROPPED
Year: 2005
Make: Mazda
Model: RX-8
Price: $7995
Mileage: 101000
Color: Silver
Location (US State/Canada/Int): GA
Has always been garaged.
2 owners total.
Clean title, no accidents, never painted.
This car has over $25,000 in modifications alone.
In the Atlanta area.
Serious buyers only please and I will not part the car or sell any of the extra parts.
See the list below with the mods.
PM me if interested. I can provide more pics and videos as well. I have the title in hand and ready to go.
Axialflow Short Shifter
Cobb Tuning shift ****
Enkei RP03 18 x 9.5” wheels
Michelin Pilot Supersport tires (255 front/265 rear)
H&R coilovers
Hotchkis front and rear adjustable sway bars
Racing Beat adjustable endlinks
Greddy front strut tower brace
JIC Magic carbon fiber rear strut tower brace
Seibon carbon fiber hood
Seibon carbon fiber trunk lid
Davies Craig electric water pump
Davies Craig electric water pump controller
Griffin oversized aluminum radiator
Flex-A-Lite high-flow dual radiator fans
Racing Beat silicon radiator hose kit
Red Horse Racing SS water lines
Pettit Racing aluminum radiator coolant tank
Pettit Racing coolant air separator tank
RX8 Performance electric water pump conversion plate
RX8 Performance aluminum lower engine pan
Greddy extra capacity oil pan
Greddy magnetic drain plug
Racing Beat SS oil lines
Rotary Performance oil cooler low temp thermostats
Black Halo Racing coil packs
MSD ignition wires
Gates high performance engine drive belts
RX8 Performance engine mounts
Black Halo Racing long tube headers
Racing Beat Rev 8 exhaust
AEM polished air intake
Black Halo Racing 9 pound lightweight flywheel
Exedy clutch and pressure-plate
Reinforced clutch pedal assembly
Mazdatrix aluminum driveshaft
Mazda Series 2 fuel pump
Mazda R3 starter
Aerospace Components aluminum battery relocation
Optima yellowtop battery
Sohn oil metering pump
Canton Racing remote oil filter
Red Horse Racing SS oil filter lines
Racing Beat radiator and oil cooler screens
Racing Beat complete gauge panel
Agency Power SS brake lines
Agency Power SS clutch line
Russel brake bleeder valves
3M premium window tint
PIAA HID projector bulbs
PIAA plasma yellow fog light bulbs
Sylvania LED bulbs throughout
Extras included:
Instruction manual with 2 key fobs and 1 spare key
Stock wheels with tires
Stock hood
Stock trunk
Stock airbox
Stock carbon fiber driveshaft
Mazda car cover
Hawk ceramic brake pads (at least 80% remaining)
Black Halo Racing midpipe with resonator
Black Halo Racing midpipe with catalytic convertor
1 gallon of Pettit Racing 2-cycle oil
4 quarts of Ideumitsu 2-cycle oil
2 Canton Racing oil filters with gaskets
Recent services (within 1,000 miles):
MSD ignition wires
OEM spark plugs
Royal Purple engine oil
Mazda FL-22 coolant
Redline transmission oil
Redline rear diff oil
Carbotech brake pads
Raybestos high-performance brake rotors
Motul RBF 600 brake/clutch fluid
Sway bars greased
Cabin A/C filter
FULLY SEMI AUTOMATIC
very clean, glws. gotta ask tho why replace the cf drive shaft?
This was the previous owner's project car and he set the car up with longevity and reliability in mind. The original CF drive shaft was fine, but he felt it was a weak point so he replaced it with a lightweight aluminum drive shaft that also has replaceable parts (unlike the CF drive shaft which is all in one.). That being said, the aluminum drive shaft is practically perfect so it would be a very long time until any parts have to be replaced.
just curious since the autos had al. drive shafts and the mt got cf. i dont remember a cf one failing and have one in garage thats been f/s for years lol. thanks and again glws
77 cylinders, 4 rotors...
REX,
Looks like a very clean car, lots of tasteful, effective goodies too. Very nice.
The elephant in the room is the compression numbers. If you throw up some pictures of a passing/above average compression test, I bet you would have multiple offers.
gixxer2go (11-04-2019)
I made it to MazCare, my local Mazda mechanic. They used a Mazda Compression tester.
Below are the numbers.
Rotor 1: 250rpm 5.8-6.2-6.1
Rotor 2: 250rpm 5.7-5.8-5.6
I was hoping for higher numbers, but the car isn't new and I'm definitely not advertising it as such.
To me, this is an example of a very well-cared for, well-modded, nearly 15 year old car. It runs very strong, revs smooth to redline, starts up cold or hot perfectly every time, never stutters, doesn't have any strange idling issues, no suspension or compartment rattles, and it has a very solid high quality feel. Anyone who sees it, can't believe it's a 2005. For the money, there aren't too many cars is this price range that can put this kind of smile on your face with the high revs, amazing balanced handling, great shifting feel, and great fit/finish. I know the pictures speak for themselves. The guys at MazCare said it was one of the nicest and cleanest RX-8's they've ever seen.
Anyways, I've decided to lower the price to $6,500. Again, this includes lots of extra OEM and aftermarket parts.
Whoever gets this ride will be very happy.
I can send videos if you PM me.
Thanks.
Thanks.
Last edited by REXTurboS; 11-05-2019 at 01:04 PM. Reason: trying to add pics, not working
200.mph (11-05-2019)
i agree team, its a sweet car but sucks its got a sprained wankel
Thanks.
Thanks.
i just a wonder if there is a possibility that their compression testing equipment has issues and/or whoever is doing the service doesn’t know what they are doing. May consider taking it to a rotary shop and having that test done again, with those numbers, should it not be difficult to fire up when the car is warm?
bluetii (11-07-2019)
Jamiesss
10-12-2019 07:32 PM
