{ FS } 2005 Mazda RX8 6-speed with 20k miles on rebuilt engine
![VA](https://www.rx8club.com/images/icons/va.jpg)
Year: 2005
Make: Mazda
Model: RX-8
Price: $7800
Mileage: 117000
Color: Grey
Location (US State/Canada/Int): VA
$7,800 OBO
Rebuild info and many other parts replaced at the same time:
- 2 NEW rotor housings
- NEW OMP oil injectors/nozzles
- NEW Exedy clutch disk
- NEW Koyo clutch release/throwout bearing
- NEW coolant reservoir (to fix faulty sensor)
- OEM apex seals
- OEM corner seals/springs
- OEM side seals/springs
- Atkins viton oil o-rings
- OEM coolant seals
- Front/rear main seal
- Atkins thermal pellet
- OEM main bearings
- Pressed oil regulator
- Oil pickup tube o-ring
- OMP to engine o-ring
Other new/replaced parts and features:
- NEW catalytic converter - Spring 2017 (resonator delete and gutted)
- NEW brake rotors - Spring 2017
- NEW BHR ignition coils and wires - Fall 2017
- NGK laser iridium spark plugs changed every 10k miles
- NEW front splash guards - Spring 2017
- NEW driver door speaker relay - Fall 2017 (comes with extras)
- NEW high torque starter - Spring 2018
- NEW Monroe rear struts - Fall 2018
- NEW O2 sensor (downstream) - Spring 2019
- NEW thermostat - Spring 2019
- Replaced amplifier - Fall 2019
- Oil and filter changed every 3k miles
- Taillight seals redone to fix common water leak problem
- Comes with extra engine undertray and car cover
- Manual transmission
- Sunroof works
- Rare stock navigation system
Only a few known cosmetic issues:
- Driver side visor broken, looking for replacement
- Latch for front middle console broken, looking for replacement
- Standard passenger side dash crack
- Hood paint partially faded
- CEL is on for gutted cat
![](https://cimg0.ibsrv.net/gimg/www.rx8club.com-vbulletin/640x480/image_1_02f558e56389ed8c761cbffa66d83e82d28c4813.jpg)
![](https://cimg2.ibsrv.net/gimg/www.rx8club.com-vbulletin/640x480/image_2_5789ff1526e2b8bee760e7d4e2284998fd89472d.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rx8club.com-vbulletin/480x360/image_3_ef2f5771f638f239cabb9d242847232d362958ca.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rx8club.com-vbulletin/480x640/image_4_b8e49bc5a55e0510bc467d7a94b2ab4763a1648c.jpg)
![](https://cimg6.ibsrv.net/gimg/www.rx8club.com-vbulletin/480x640/image_5_5ec23dd48924f31959a19b5fecf114096ec699ec.jpg)
![](https://cimg7.ibsrv.net/gimg/www.rx8club.com-vbulletin/480x640/image_6_67fe5ced6160e3d4d5220981aebd0e2faca44688.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rx8club.com-vbulletin/640x480/image_7_41f694682913045282b59566fe48b40e1b515279.jpg)
![](https://cimg1.ibsrv.net/gimg/www.rx8club.com-vbulletin/640x480/image_8_03415d7aa88920a0edfb63af895336e842d00a45.jpg)
![](https://cimg2.ibsrv.net/gimg/www.rx8club.com-vbulletin/360x480/image_9_c8a205d3acf11f334070cee2aece60498b2a67a9.jpg)
![](https://cimg3.ibsrv.net/gimg/www.rx8club.com-vbulletin/360x480/image_10_69b1a605919a3d3e5e53a52da7021d0d8d99d657.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rx8club.com-vbulletin/640x480/image_11_6791f5ea54e8b4b1c1c34f377e925a73afa789d0.jpg)
Dynamite_Goat
09-04-2020 01:53 PM
k-Tracker
07-05-2018 12:44 PM
Matt PN
01-10-2012 10:10 PM
