{ FS } 07 Mazda RX8 Street & Track, perfect for HPDE
(SOLD) 07 Mazda RX8 Street & Track, perfect for HPDE
Year: 2021
Make: Mazda
Model: RX-8
Price: $8500
Mileage: 96000
Color: Sunlight Silver
Location (US State/Canada/Int): MD
Chassis has 96k miles, engine has 20k miles (dealership warranty replacement). Sport model w/6 speed, LSD, no sunroof, no traction control, the lightest factory package. Always garaged, no rust or winter driving. No accidents and clean CarFax. Car weighs ~2850lbs with no gas or driver. Car has been thoroughly sorted for HPDE.
Interior: 4pt. Piper Motorsports weld-in half cage, Schroth Harnesses, and OMP seats (factory seats available) otherwise full interior with working radio, A/C, and heat. The clutch pedal bracket has been replaced with a welded reinforced one.
Engine: Black Halo Racing Ignition Coils, AEM intake, AGM Battery, Epitroch SOHN Adapter (burns 2 stroke oil from a separate reservoir instead of crankcase oil), Cobb Accessport tuner, custom long tube headers. Header back is modular using v-bands, install the high flow cat to pass emissions or run the test pipe section, from the axle back a magnaflow single exit muffler is available or straight pipe all the way out. Extremely convenient.
Suspension: Bilstein PSS9 coilovers, Offset UCA bushings, Hotchkis MX-5 Swaybars w/adjustable endlinks
Brakes: Hawk HPS street pads, Hawk Blue track pads.
Wheels: new Mazdatrix front hubs with extended wheel studs, factory wheels w/245 Continental DWs,
Spare trunk w/APR GTC-200 wing
Motorsports grade fluids throughout, dialed in and reliable, and owned by an OEM vehicle test engineer. Wing and wheels are negotiable. No trades. Selling because I’m moving to a track only racecar. Car competed at Nationals in STX prior to my purchase under Shawn Lambert.
Car did a 1:50.3 at Mid-ohio last weekend with the key hole chicane. That was just from one session, no idea what the fastest time of the day was. Time was set on the Maxxis set, no idea if it's fast though.
The Continental slicks are officially retired, one's got a cord showing through. Car has brand new track brake pads front and rear.
Just the car on factory wheels with stock trunk. $8500
Add the 949 wheels and Maxxis tires for $1500
Add the spare trunk with APR wing, $1000
jay_tibo
22
09-13-2016 08:10 PM
