{ FS } 2008 40th Anniversary Parts
I will check the battery/starter harness. The battery terminal may have been corroded to the point where I just cut it off. Did you need the rear differential/axles/hubs etc with the subrframe? Do you want just the fuse BOX top and bottom, or were you wanting the whole box, with fuses, and wiring harness? Trunk weatherstripping has tears, and I unfortunately tossed the stock cat-back a few months ago after having it listed for over a year.
my apologies between being a newbie to forums and working from my tablet ( it seems to give me limitations), my last reply was meant towards the response 40th8Jake had given. I did send him a PM.
Well I’m actually interested in the faceplate for the radio/climate control as mine is cracked at one of the screws so it does what it wants sometimes. Is yours in good shape?
not so much the other things anymore since I’m doing REW swap, getting a 5 speed trans. Just need functionality..
I believe the differential is different. No LSD from what I understand. So you need the entire rear minus differential? You need axles too or no? I will be able to check starter harness tonight. Bottom half of fuse box $35?
Yes, everything attached to the rear subframe minus struts, springs, diff and axles. Yes on the fuse box also.
