{ FS } *FEELER* Aftermarket parts & more partout
#26
Price: $0
Location (US State/Canada/Int): CT
I will be traveling through CT the weekend after this coming one 4/13 + so I can pick up
I am interested in the following:
BHR resonator midpipe w/ O2 bung
AFE SS
Racing Beat 3-gauge dash panel
Prosport Premium (w/ peak/warn) Oil Pressure gauge
Prosport Premium (w/ peak/warn) Oil Temp. gauge
Prosport Premium (w/ peak/warn) Water Pressure gauge
Prosport Water Temp. Sender Radiator Hose Adaptor
Prosport Oil Filter Adapter Plate
Stance GR+ Coilovers
Progress Tech. Front Anti-Roll bar
Progress Tech. Rear Anti-Roll bar
Evo-R End Links
SOHN OMP adapter
AEM CAI kit
Mazmart RE-medy Hi Flow Water Pump
Mazmart RE-medy Thermostat
Clear RX-FX Side-Marker Set - Silver
Are the parts still on the car? Can I get pictures of these things? Would you work out a package?
AFE SS
Evo-R End Links
SOHN OMP adapter
AEM CAI kit
Yes they're all on the car, but the car is on jacks since fall since I don't drive it in the winter and has all fluids drained. I could see if I could yank all those parts off before the weekend next week (I'm gone all this weekend).
If you want pictures all I can give for now is in their installed state, nothing isolated from the car. Otherwise next week once I start to pull items off I can take pictures and post them up here.
For a package.....I think I could work something out depending on the higher priced items if they're bought or not (coilovers). Otherwise I won't be willing to take off much with everything already low as is.
that would work.
#34
I'll be posting pictures next week. Keep in mind most of these parts are on the car so unless you want pictures of them installed (with a few body parts the exception), then I'll be getting to this next week once I start the progress of removing all said items and make this official.
I'll update the listing here for dibs based on local/pickup or shiipping and the order you expressed interest.
#37
#39
*UPDATE*
Listing has been updated with the names of those interested in the parts. Pictures will be following this week. I will contact those 1st in line with the shipping quote (unless local/pickup) and payment information.
For local/pickup I will contact you to establish a meeting time and payment method.
#41
Time for boost...
How the @#!% did I miss this thread?! For the better I guess, as my VISA is gonna be taking a hit soon (you couldn't have waited a month or so to list this?? )
Anywho, could you please add me as interested in BHR midpipe, all prosport gauges/addapters, shipped to Canada (R2M 0B2).
#43
Below are pictures of the Stance GR+ coilovers. Surface rust is on the threads which I'll clean up before sending out.
The note on the rear adjustment snapping off is shown here; it seems that the adjustment is neutralized at the current setting which is 12 with 14 being the stiffest.
Set comes with all tools that came with them.
#45
Prosport gauges w/ RB gauge pod
Gauges operating w/ key turned to "On" position
Prosport gauges & RB gauge pod
RB gauge pod that highlights a hairline crack on the side. This is exactly how I received it, likely poor packaging or shipping abuse. Regardless, it's trivial; there is no tension in this area and it's all hidden once installed.
#47
AEM kit
Clear side-marker set
Clear side-marker up close
As shown, somehow there are scratches within the middle that developed over the winter and I'm stumped as to how this occurred since they are not on the outside nor the inside of the lens and were not there when I put the car on stands last fall. Because of this I'm reducing the price down to $25.
Prosport water & oil adapters, Mazsport thermostat and SOHN adapter
Custom made bracket to replace secondary air pump valve
