{ FS } 2004 RX-8 GT 6 speed Complete Part Out
#26
Private or Vendor Listing: Vendor Listing
Location (US State/Canada/Int): NJ
secondary air injection pump
fuel lines (the two from the engine to that little hook up in the engine bay)
cat
long o2 sensor
fuel regulator? If it's apart of the fuel pump I'll take the fuel pump.
All the fuse and relay boxes with the fuses and relays in them.
maf
#27
Former Sponsor
Hello, I've got a decent list of things I need. Could you give me your price, and if you want how firm you are on those prices?
cat
long o2 sensor
maf
cat
long o2 sensor
maf
Plastic fuel lines from motor to firewall: $25
Cat: $100. Really recommend a high flow
Long O2 sensor: $50 recommend new.
There is a regulator built into the fuel rail
Which relay box? The one in the engine bay on driver's side? $85
Maf: $100
#28
Definitely want the fuel lines, cat, o2.
From what I've been told and have read the regulator is with the fuel pump, but i don't know if they're one unit or if they can be separated.
Give me a little bit to figure out which boxes I actually need, I know there's one in the foot well, would that be $85 also? Just to be clear I want all the fuses and relays too
#29
Actually would you sell the wiring harnesses? The one with the relay box is the one I need the most
#34
How much would shipping be to 40214 louisville ky
#36
#39
what about just the aluminum part of the intake with all the ssv valves and etc still attached for 50$ plus however much you want for the corner lights if you still have them.
#42
I've recently ported my irons and i was matching these to the new port however i accidentally matched the front tube to the rear iron before i realized my mistake and went to far to match it back to the other side. also the corner turn signals if you have them.
these: https://www.rx8club.com/attachments/...-wp_000060.jpg
#43
Former Sponsor
alright so were getting somewhere now i fear I might not have been clear on my very first post. would you be willing to sell me just the tubes that come out of the intake manifold and go into the irons. the 2 tubes at the bottom of this picture http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/pBUAAMXQVERSz0J~/$_35.JPG
#48
