{ FS } Engine/Extra Misc parts
#31
Haha no, sorry I should've specified a little better. The battery terminal clamp PN# F151-67-TB1. Theyre like 20 something bucks online but If yours is in good condition then theres not much of a differance then ordering off of ebay or something, much rather the money go to someone on here.
#35
parts for sale
Hello I am looking for the passenger front brake line from wheel well to abs module, upstream and downstream o2 sensors, driver side sun visor ( if not beoken), the engine A/c pulley that goes on the eshaft and the jumper harness that connects the starter, park neutral safety switch, reverse switch, engine ground pattern connection to the fuse box. It is a separate harness and is not part of the engine sensor harness.
#36
I have a rear 02 sensor for 50.00, I have a driver side visor very good condition 50.00, I have the eccentric shaft pulley/trigger wheel set for 30.00 and I have the battery harness (the harness you referred to) for 50.00. I don't have the brake line. I can do 200 shipped for all.
#42
#43
I have for sale extra parts from imported jdm long block as well as 06 rx8 Shinka edition. Jdm is estimated to have 50,000 miles and had good compression. Shinka engine lost a rear apex seal at 94,XXX.
All items are used and in working condition.
Buyer is responsible for shipping. USPS unless otherwise specified.
I will update list as if find more parts.
My paypal is bradalot@hotmail.com
ALL PRICES OBO
Upper intake $100 SOLD
Throttle body $50
Engine harness bracket $40
Complete engine harness: $150
Transmission shifter $50
Thermostat housing $25
Coolant housing $25
OEM Exhaust manifold (2) $25
OEM New Flywheel (2) $50
A/C compressor $50
Front Counter weight $50
Crank shaft trigger wheel and pulley $50
Trigger wheel position sensor $30
OEM water pump $50
Alternator bracket $25
Alternator (2) $50 one painted black
OEM coil kit with bracket, nuts and wires (verified in good condition, unknown mileage) (2 sets) $50
Oil injector air tube $30
Oil pump and associated part (within spec) $50
Battery harness (2) $50
Oil pans (one is like new) $75
Injectors yellows $50 SOLD
Injectors red $30 SOLD
Fuel Rails $10
OEM side marker lights $25
OEM ECU (JDM) $100
Complete air pump $25
Oil filter pedestal (2) $25
OEM starter $25 SOLD
Brand new Lower intake gasket $50
Exhaust header gasket -Like brand new (mounted once for 4 mile drive-engine pulled) $25
Air intake accordion tube $25
OEM GT struts and springs (44,000 miles) $50
Brilliant black Passenger and Driver rear doors $300 each (ship via greyhound) paint is 5/10 with various paint chips and minor scratches. No dents
Various suspension control arms $25 a piece
OEM Catalytic converter perfect honeycomb $350
Used AP midpipe $150
Windshield wiper motor $30
Windshield wiper plastic trim $30
Cigarette lighter $15
Front cover $30
Moon roof motor $30
Moon roof $250
Driver side sun visor $50, passenger is cracked $5
Brilliant black Passenger door $800 (ship via greyhound) Paint is 5/10 with various paint chips and minor scratches. No dents
Front control arms $50 each
Rear trunk door plastic support $10
Rear trunk door $20
Front under brace $50
Brilliant black gasoline lid $25
Master cylinder $50
Black carpet complete set, uncleaned in good shape with no unraveling or tares $50
Driver side motor mount bracket $25
Hood latch $20
Differential, known working with 44,XXX miles $75
Rear windshield interior plastics, set $50
Fuse box cover $10
ABS controller $75
Door tweeters passenger and driver $25 each
OEM stereo (know to work) $50
Series 1 fuel pump and canister (2) Pumps both known to work $50 one with unknown milage the other with 44,XXX
TPMS (1) $25
Power Steering harness $50
Used OEM clutch with no issues (rusty) $30
Foot panel with chrome rx8 emblem $20
Half shafts (2) $30 each
Hubs (4) $50 a piece
Brake calipers (3) $45 each
Complete fuse box harness including fuse box $150
Rear speakers (3) known working $25 each
Ash tray liner $10
Horn $10
Side air bags (2) $50 each
Hood latches (2 sets $20 each
Brilliant black trunk with spoiler $300 (ship via greyhound) Paint is 5/10 with various paint chips and minor scratches. No dents and all emblems
Fuel pump access door (2) $10 each
Battery air dam $10
Fender/oil cooler liners (1 set) $40, one is slight damaged but could be made to work
Trunk plastic jack case $20
Windshield wiper arms (1 set) $30 extra one $15
Front subframe $100
Rear subframe $100
ALL PRICES OBO
Throttle body $50
Coolant housing $25
A/C compressor $50
OEM water pump $50
Fuel Rails $10
OEM ECU (JDM) $100
Front cover $30
Moon roof motor $30
Moon roof $250
Rear trunk door $20
Master cylinder $50
Hood latch $20
Fuse box cover $10
ABS controller $75
TPMS (1) $25
Ash tray liner $10
Horn $10
Battery air dam $10
Front subframe $100
Rear subframe $100
#50
No trunk trim pieces Supido-Kyo.
Dravethe, I have a set but I don't trust them that much. I've done the blow test and a little air will get through it seems. I can let them go for real cheap though like 20 bucks shipped and maybe you will get a couple good ones.
