{ FS } 05 RX-8 WWP Full Part-out OEM and Aftermarket
#76
on
Location (US State/Canada/Int): PA
on
Do you have the wiring harness for the heated seat switches? Don't need the switches those I know you sold already but the plugs and as much as of the harness back as you can get?
#85
Posted From RX8Club.com Android App
#92
Also here's an updated list of things I need.
MAF (I'm not sure if it was you, but someone on this forum said $60)
Barometer
Keys, key fob, immobilizer (black box in passenger footwell, should have visteon label. Also if you found anything else with visteon labels, let me know)
The coil off of the ignition switch. I don't know if it can be popped off, but if it can, that would be sweet.
I'm swapping a renesis into my miata, and I'm not sure what to do about the fuel system yet, so could you give me your price for everything in the gas tank? (pump, regulator, filters, scavenger tube, etc) If it's a hastle to figure out, you don't have to bother, I'm just curious.
#96
Originally Posted by tapeman
Originally Posted by ruskivovka91 ?
I do have the harness but don't really want to cut anything so I'll check where it all goes.
Is he talking about the really big harness? If so, I'll take the front half of it, like if you cut it off from where it leaves the dash and goes into the side of the car, that would be perfect for me.
Barometer
Barometer
I can do the MAF for $60, that's fine.
parts with the keys I have pending for a guy switching auto to manual. if he back out I'll let you you know.
I can do fuel pump assembly for $125. basically what's with it when I take it out of tank. if there are additional things we can see then.
