{ FS } Turbo Kit
HAVOC
on
Turbo Kit - $4000
Category: Engine - Power Adders
Price: $4000
Location (US State/Canada/Int): GA
Comes with:
Greddy Turbo manifold (2400 degree ceramic coated ::faster spool times:: )
Greddy Turbocharger (less than 8 thousand miles on the turbo)
Greddy downpipe (2400 degree ceramic coated, drilled and tapped for EGT sensor)
Greddy Wastegate
Greddy Turbo piping (all pieces included)
Greddy Turbo Outlet pipe (drilled and tapped for vacuum hose for better wastegate reading (greddy fix))
Greddy intake pipe (HKS BOV flange welded)
Greddy Intercooler
Greddy air intake filter
Greddy MAF housing
BHR samco couplers (blue- replaces cracked greddy couplers ::best on the market:: )
T-clamps (much stronger than worm or s clamps)
HKS SSQV BOV (vacuum hose included)
All new oil fittings!
Russell aluminum 3 way fitting (for oil inlet)
2 Russell aluminum AN adapter
Russell 3 AN oil feed line (already cut and assembled)
oir restrictor (keep turbo bearings from being damaged ::greddy fix:: )
specialty welded oil outlet pipe (adapted to 5 AN)
Russell aluminum 5 AN to oil pan adapter
Russell aluminum 5 AN oil drain line (already cut and assembled)
Prosport electronic boost gauge (:white/blue: brand new sensor and vacuum lines NIB)
Prosport EGT gauge (:white/blue) brand new sensor, NIB)
Prosport narrowband AFR gauge (:white blue)
All new fittings!
every bolt and nut was specialty ordered with high grade automotive steel to replace the stock greddy nuts and washers.
All gaskets are also included.
deep well 13/16 socket also included to remove and reinstall oil pressure sensor
(reserved for pictures)
I zoom therefore I am.
damn good kit for anyone wanting to go FI. Do not look at this price and think you've seen it cheaper. This is not some ebay special, this is a fully redone turbo kit... everything you'd think of upgrading to make it bullet proof has been done.
If I wasn't already going another way i'd be sending my money.
