{ FS } F1 Racing Stage II clutch kit
on
F1 Racing Stage II clutch kit MUST SELL
Category: Drivetrain
Price: $100
Location (US State/Canada/Int): IN
here i am selling a F1 racing stage II clutch kit i got off gripforce clutches "store" off ebay, Never been mounted. my clutch was never in bad shape i thought it was the reason why i was grinding at high RPMs but after i installed the stainless steel clutch hose it shifts like butter with no issues at all thanks to the members here who helped me out is it too much, NAME YOUR PRICE!! 48 states shipped for 15$$
on
ill ship anywhere, im using a flat rate box, "if it fits, it ships" but i think international goes by weight, up to 4pounds is 15 and up to 20 is 26 bucks and some change
on
i got it off of an ebay store 'highperformanceoutlet' the clutch line is made by agency power and many other dudes around here carry it, i just got it cheaper, 36 bucks free shipping. raceroots.com has it
on
F1 Racing STAGE 2 clutch kit is a step up from our Stage 1 clutch kit. This is a versatile set up for the street and on the track. It provides a smooth engagement yet it can holds 50%+ more power over stock clutches. This is a direct factory replacement clutch kit thus no modifications are needed and the clutch kit includes only the highest grade components from world's leading high performance clutch manufacturer. The Carbonized kevlar friction material is used on all Stage 2 clutch kit to have higher burst strength and heat tolerance. The heavy-duty sprung center with heat treated springs and retainer rivets to increase strengh and reliability. The F1 Racing pressure plate features special single diaphragm design to increase clamp load. It features induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. F1 Racing pressure plate provides smooth and precise feel with easy modulation. All F1 Racing pressure plate is load tested on a special testing tool for quality assurance.
This complete clutch kit includes:
F1 Racing Stage 2 Heavy-Duty Pressure Plate
F1 Racing Stage 2 Disc (240 mm, 23 spline)
Release Bearing
Pilot Bearing
Alignment Tool
Installation Guide
Horsepower Rating: 465 HP / Torque Capacity: 331 ft/lbs
Retail Price: $ 479
Release Bearing
Pilot Bearing
Alignment Tool
Installation Guide
Retail Price: $ 479
