{ FS } Used GREDDY Turbo kit, mostly complete
Category: Engine - Power Adders
Price: $0
Location (US State/Canada/Int): TX
Instruction manual for reference is here: http://www.greddy.com/upload/file/03-RX8_TK_T618Z.pdf
Pictures are attached. I bought these parts from someone else. They have not ever been installed or used by me. As far as I can tell the kit is mostly complete except there is no e-manage, wiring harnesses, or air filter assembly. Everybody knows to use a different PCM controller/tuner such as the Cobb AP etc. and also a different airfilter setup such as a modified AEM/Mazdaspeed assembly. The manifold & downpipe have a black ceramic caoting applied to them and both appear to be in excellent condition. The turbo also appears to be in very good shape, but it was my intention to have it upgraded by BNR prior to installing it. I did not go through every single clamp, nut, and bolt, but the important pieces all appear to be there. It includes both the original and brand new silicone couplers. The new ones are Samco brand. It also includes an OE oil pan (stripped, no internals) and the card in the middle of the parts pic is a weld bung. The bung appears to for installing it in the oil pan for the turbo oil drain line and then swapping all the internal components over onto it from your oil pan on the car.
There are a few vacuum lines included, but I bought the kit with the understanding that all new ones would be required. There is an on-going thread in the Series 1 Major Horsepower Mods forum on the proper vacuum line setup for this kit. I cannot say what if any MM modifications have been performed. The large aluminum elbow has been modified. It has a port welded onto it and includes a generic (no-name or markings on it) blow-off valve and gasket that mounts to the port. One end of the elbow appears to have been cut off with some type of rubber adaptor fitted in the end. I will provide a straight piece of the proper size aluminum tubing to restore the end that has been cut, but you would need to cut it to the proper length and provide a silicone coupler and clamps to attach it with the elbow. These are all minor things to me, but you may feel differently about it. I don't have any problem shipping the kit. My location is near Dallas, TX.
SOLD
it can mean both, but I meant the not possible option. After 6 years on this forum do you realize how many FS posts I have read where somebody said they'd have the money at xyz time only to never be heard from again? I can't even recall one time where they actually came back to make a purchase in that thread. Either you buy now or you don't, thats the way I see it. No offense intended. You may be different, but it would be a first in my book.
WENTGERMAN
We'll see what happens!
Moar Low!
on
on
very tempting but the last "almost complete" turbo kit i bought from a douchebag in canada is still sitting in my closet as a lost cause. $1800 seems a good deal but i am a firm believer in you get what you pay for.
