{WTB} Intake/Header/Exhaust
Old 11-19-2011, 11:56 PM
stangcobra's Avatar
Category: Engine - Intake/Fuel
Price: $450
Location (US State/Canada/Int): NC
My friend recently got a series 1 rx8, its the first car he's modifying so I've decided to help him with it. I have had an extensively modified 4th generation eclipse and SVT Cobra so I know my way around an engine a little bit. That being said I am looking for some gently used parts to add a bit of power to his car, I'm guessing intake/header/exhaust/tune is the standard with these renesis rotaries.
He has up to $450 to spend, so I am looking to maximize what he can get out of it.
Old 11-20-2011, 12:00 AM
paimon.soror's Avatar
suggestion: have him put the 450 towards a new set of coils, plugs, oil filters, etc. If general maintenance has already been done, forget intake/exhaust and use the money to get a Cobb. Else, save the money for future issues he may encounter.
Old 11-20-2011, 08:48 AM
WENTGERMAN
shadycrew31's Avatar
Stock intake is the best flowing, you can get a green air filter that's as much as I'd do on an NA. Also the stock header flows just fine.
The only mods that net power for this car is cat removal/porting/cobb accessport+tune. in the future the BHR long tube header should net some gains.
To support power output and reliability
Ignition upgrade, grounding kit, oil changes, plug changes.
Everything else is a scam/a great way to lose money.
Old 11-20-2011, 11:00 AM
stangcobra's Avatar
Hmm okay then, I suppose I'll have him invest in some kind of test pipe+cat back, I can do ground wires without the kit, so then all he'll need is the accessport.
Are there any other way to make gains on this engine? other than boost obviously, I just cant see there being only three(give or take) mods to do to it. What about underdrive pullies or that plasma ignition that was in 2nr a little bit ago, either of those do anything?
Old 11-20-2011, 11:13 AM
WENTGERMAN
I would start off with getting some premix (idemitsu or 2 cycle oil), the BHR ignition, new plugs and an oil change.
Then get a mid pipe, then get the cobb and a tune.
That should leave him with close to 200whp, assuming the engine compression is good.
Old 11-20-2011, 05:33 PM
stangcobra's Avatar
This has been...enlightening to say the least, these engines really dont make much power lol
Old 11-20-2011, 05:42 PM
WENTGERMAN
Hahaha nope!
It's all about the handling.
Old 11-20-2011, 06:43 PM
Former Vendor
BennettBuilt's Avatar
I have,
LS2 Ignition setup
AEM V2 Cold air intake
Exoticspeed Catless midpipe
Full wet nitrous kit
If he wants any of this let me know.
