{WTB} 09-11 6 speed manual transmission
Old 04-06-2012, 07:37 AM
jwpierce3's Avatar
09-11 6 speed manual transmission (PROBLEM SOLVED - NO LONGER NEEDED)
Category: Drivetrain
Location (US State/Canada/Int): MS
I'm looking for one of these. Mine needs rebuilding and I suppose replacing is better. However my current 05 still works. Apparently the synchronizing ring is going out on it. Does anyone want my old one when it comes out?
Old 04-11-2012, 11:00 PM
jwpierce3's Avatar
I'm sure this problem is in the forum somewhere, but I wanted to share my findings here anyway.
I found that the flex hose from the master to the slave cylinder was flexing and bad. So my tranny is ok. If anyone else is having a problem shifting check out the hose. When the hose gets hot it starts flexing under load and doesn't disengage the clutch fully.
I would like to switch out the transmission but seeing that mine is still good I think I will continue to use it.
I also found this product online:
http://www.friktiontek.com
*I am not a reseller of this product*
The owner recommended it to people with older engines because they would see a difference but I thought that I would use it for Preventative Maintenance measures. Racing engines are sprayed with a ceramic before assembly. I put it in my tranny and engine.
Old 04-24-2012, 11:58 AM
jwpierce3's Avatar
BUMP for solution
Old 04-24-2012, 12:39 PM
Chris
rxsevenor8's Avatar
sorry completely off topic... would you be able to help me out with a custom swap/setup im building in my 8?... i need to know the length of the rx8 MT from the shifter to the motor... if you could thatd be wonderful...
good luck with your solution, wish i could help.
thanks
chris
Old 04-25-2012, 08:28 AM
jwpierce3's Avatar
I'm sorry. I have not taken my transmission out so I don't know.
Old 04-25-2012, 07:03 PM
Chris
rxsevenor8's Avatar
its alright, figured id try.
thakn you and good luck with your problem
chris
Old 04-25-2012, 07:13 PM
WENTGERMAN
shadycrew31's Avatar
i'm sure this problem is in the forum somewhere, but i wanted to share my findings here anyway.
I would like to switch out the transmission but seeing that mine is still good i think i will continue to use it.
*i am not a reseller of this product*
the owner recommended it to people with older engines because they would see a difference but i thought that i would use it for preventative maintenance measures. Racing engines are sprayed with a ceramic before assembly. I put it in my tranny and engine.
lol.
02-10-2020 10:23 PM
ed0128
09-09-2015 04:50 PM
Anthony Kevin
09-07-2015 07:36 PM
titaneum_grey
09-06-2015 10:21 PM
nivong
Europe For Sale/Wanted
09-02-2015 07:54 AM
Quick Reply: {WTB} 09-11 6 speed manual transmission
