RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } RX8 Race Car SCCA/STU and NASA PTB/PTC
Old 08-29-2012, 10:00 AM
Eric Rosenberg's Avatar
Year: 2005
Make: Mazda
Model: RX-8
Price: $23500
Mileage: 5000
Color: Orange and Red
2005 Mazda RX8 race car
Built from new - The car is breathtaking
PRICE REDUCED ANOTHER $500, we're asking $23,500.00.
General overview
- Originally built by Roar Racing for the Koni Challenge Series (this was their 4th team car and never raced)
- Re-race engineered by Joe Geldert, Crew Chief for Autocon Motorsports ALMS P1 and GT1 race cars, of Escondido, California (9 months ago)
- Revised engine and diff cooling fabrication and plumbing provided by Twin’s Turbo of Signal Hill, California (4 months ago)
Motor
- Engine built by: MAZMART (approximately 10 hours)
- AEM dry flow cold air intake
- Dual Setrab engine oil coolers
- Wix oil filter (Remotely mounted)
- RC Engineering matched fuel injectors
- Moroso brand spark plug wires
- Speedsource Eccentric shaft and Alternator pullies
- Dynotuned header
- ACT clutch
- ACT flywheel
Electronics
- AMB transponder
- AIM MXL Pista gauge
Suspension
- Koni 2800 series shocks
- Eibach springs
- Racing Beat sway bars
Brakes
- Freshly rebuilt calipers
- New OEM front and rear rotors
- New Cobalt pads front and rear (Model #:XR1 Fronts, XR5 Rears)
- New OEM front and rear brake mounting hardware
- Goodridge brand stainless steel brake lines
Engine Cooling
- Custom Ron Davis Radiator
- Radiator Swirl Pot by Pete’s Speed and Fab
Differential Cooling
- New Setrab oil cooler with fan pack
- New Tilton brand Oil pump
- New Peterson brand in-line Oil filter
- Newly installed and plumbed
- NACA ducting and Plexiglas windows installed on the rear doors
- 3” cool air hose routed to oil cooler
- New 6” differential overflow tank
Chassis
- Freshly rebuilt differential with ’09 final drive ring and pinion (All new OEM Bearings, seals, crush sleeve, and pinion nut)
- New halfshafts
- Mazdaspeed Strut tower bar with built in brake master cylinder brace
- Axia flow short shift lever
- Fresh OEM rear suspension hardware
- Fresh OEM driveshaft hardware
- New OEM ball joint boots
- ARP wheel studs
- Racing Hart wheels (17x8) (1 set)
Driver Safety
- Peter Gilbreath (Pete’s Speed and Fab) built roll cage
- Sparco driver seat (Evo L)
- Sparco passenger seat (Evo L)
- Brand new Safecraft driver’s side belts
- Sparco passenger side belts
- Window and Safecraft inboard intermediate nets
- Sparco steering wheel and quick release hub (Weld on)
- On-board fire suppression system - Safecraft
Paperwork
- Orignal vehicle registration paperwork
- Tons of set up notes from the team owner and crew
- OEM factory shop manuals
RX8 spares package
- Four sets of NEW Colbalt racing pads – rear (model XR5)
- One set of NEW Colbalt racing pads – front (model XR1)
- Rebuilt transmission (’04-’08)
- Engine – short block
- Lower Intake manifold
- Speedsource pulley set (E-shaft, Alt., and OEM water Pump)
- ACT Flywheel
- Set of half-shafts
- New rear caliper
- Set of front aluminum A-arms (Upper and Lower)
- Set of rear control links (Complete set?)
- Safecraft fire bottle (Full charge)
- New OEM water pump and gaskets
- 1 ½ sets of matched fuel injectors (RC Engineering)
- New OEM brake master cylinder
- New OEM clutch master cylinder
- Set of ARP wheel studs
- AiM Beacon
- Goodridge steel brake line set (new in the box)
- (2) AiM temp sensors
- Check valve
- Misc. electronic connectors
- (2) oil pressure sensors
- (2) new rear wheel brake harnesses for the ABS system
- Hood (OEM Aluminum)
- Set of front fenders
- Set of rear door ¼ glass
- Chassis wire harness (minus engine harness and trunk harness)
NOTE: We literally have hundreds of photos of our race car that we can share. Please e-mail with any questions. Please provide your e-mail if requesting photos. I'd love to post photos but I can't figure out how to on this site....
Thank you.
Attached Thumbnails RX8 Race Car SCCA/STU and NASA PTB/PTC-img_9634.jpg   RX8 Race Car SCCA/STU and NASA PTB/PTC-img_9635.jpg   RX8 Race Car SCCA/STU and NASA PTB/PTC-img_9637.jpg   RX8 Race Car SCCA/STU and NASA PTB/PTC-cal-speed-6-10-2012-1.jpg
Old 10-01-2012, 07:43 AM
Price REDUCED another $500. This is a complete and ready to run RX8 race car eligible for numerous SCCA and NASA classes.
Check it out.
F51
08-02-2021 04:07 AM
Mr. Pockets
RX-8 Racing
19
10-17-2019 08:03 AM
JakeKaminskisRacing
08-23-2015 01:10 AM
AussieGray
07-16-2015 03:58 AM
Quick Reply: { FS } RX8 Race Car SCCA/STU and NASA PTB/PTC
