{ FS } tons of stuff for sale
Location (US State/Canada/Int): TX
Below is an updated list of the items I have for sale and over the next few days I will be adding more details but I wanted to get the ball rolling. All prices are OBO (but dont be a douche) and DO NOT include Shipping.
Item:
Sunroof wind deflector (with hardware) $40 OBO
Aluminum Undertray new $120
Racing Beat H2O adapter $25
SPAL oil cooler fan $50
OE Rims (minor curb rash not shoes) $65/wheel
Sunroof (broken cable) $50
Tail Light (DS) $25
OE Brake Lines $10
OE Brake pads $20
OE Radiator $125
OEM Flywheel $50
Engine Cover (7 of them) $74
E-Shaft $100
Housings $250
Irons $250
Front Cover $250
Oil Pump $75
Oil Metering Nozzles $25
Oil pressure regulators $10
OMP (5 units) $500
OMP Lines $40/line
Thermostat $10
Thermostat Housing $50
Water Pumps $50
Fuel Rail w/pulsation dampener $50
Injectors-red $50/injector
Injectors-yellow (cleaned and flow tested) $50 /injector
Plug Wires-OEM $20/set
Actuators $50
Air Box Tray $20
APV motor w/shield $100
LIM $150
SSV $50
Throttle Body $250
UIM $50
VDI $50
VFAD w/actuator $50
OE Intake $75
Racing Beat gauges $50/gauge
Air Pump $30
Alternator Bracket $15
Corner lights-yellow $20/pair
Tire Pump (missing repair fluid) (3 units) $50
Eccentric shaft position sensor $25
H2O Sensor $20
Knock Sensor $25
MAF $35
OE End Links-Front $25
OE Springs $50 /spring 12 avail
OE Shocks $50 /shock 12 avail
Sway Bar-Front $50
SARX Coilover Suspension ALL NEW PARTS $1300
KY OEM Shocks
1 - 2004 GR in VR, full partout (not included in the above list)
There are multiples of every OEM part you can think of even if it is not in the list. I have purchased and sold over a dozen RX8's...so if you have a question let me know.
the 4 on the Right are basically brand new (I was in denial my compression was low) the 2 on the left I picked up form someone else and are pretty much new (although you can see the 1 has a small spot.... this spot is not indicative of a failing coil...just fyi
they can come in just about any color you want
they are also built to the customers specs....you want stiff we give you stiff, you want comfy we give you comfy...you want progressive ride we do that too just not for the list price...lmao
