{ FS } 2007 Mazda RX8 Touring - 6spd - 65.1K Miles
Year: 2007
Make: Mazda
Model: RX-8
Price: $11500
Mileage: 65200
Color: Grey
CLEAN TITLE!!
Touring Package Includes: Self-leveling Xenon high-intensity discharge (HID) low-beam headlights; fog lights; Dynamic Stability Control with traction control; limited-slip differential, 18-inch wheels and tires; larger front brakes; sport-tuned suspension
+ Sport Package items plus 300-watt Bose® 9-speaker audio system with AUDIOPILOT automatic noise compensation technology; power sliding-glass moonroof; auto-dimming mirror with HomeLink® system
This Car is Clean in side and out side, runs perfect without any mechanical issues. This car have recently been smog, registration paid until April, 2014. Recently Service Includes the following: (I have all receipts and documents for all the work and parts purchased)
- Engine Compression Tested at 105psi front Rotor and 105 psi rear rotor and received "Good Compression" rating at Lucky 7 Racing. -
- Dunlop Direzza DZ101 Tires with 70% tread left on all 4 tires.
- Laptop mount
- Ipod/Iphone Connection
SERVICE PERFORMED DATE MILES
Smog check............................................7/30/2013...............63,900
Replaced Driver side outter Control Arm....8/1/2013...............63,900
Replaced Front and Rear Brakes pads with Hawk HP plus ............................9/12/2013........64,472
Replaced Spark Plugs with NGK Laser Iridium Spark Plugs.........................8/29/2013........64,303
Replaced Spark Plug Wire with NGK Ignition Wire Set...............................8/15/2013........64,303
Oil Change with Eneos 5w/30 full synthetic oil............................................8/29/2013........64,303
Replaced Oil Filter with K&N PS-1008 Oil Filter.........................................8/29/2013........64,303
Replaced all (4) Ignition coils with OEM Ignition Coils................................8/22/2013........64,303
Replaced Wing due to clear coat pealing with OEM Mazda RX8 Wing..........9/11/2013
Changed Transmission Oil with Red Line MT-90 Manual Transmission Oil...9/12/2013........64,472
Changed Rear end fluid with Red Line 75W90 Synthetic Gear Oil.................9/12/2013........64,472
Full Alignment Performed......................................... ..................................9/17/2013........64,550
PLEASE NOTE:
This car is under Mazda 8 years/ 100K Miles Extended Engine Warranty (expires July/ 2015 or 100,000miles)
This warranty will cover the following:
- Rotary Engine Core
- Rotary Housing and Internal Parts
- Internal Seals and Gaskets
More information can be found on Mazdausa's website or by calling (800) 222-5500 and be verified with the VIN # of this vehicle.
http://www.mazdausa.com/MusaWeb/musa...ner_letter.pdf
I originally purchased the car with every intention to keep it for a very long time, so I spent a lot of time, effort and money trying to make the car perfect. But recent family plans have changed and we need a bigger car. So its up for sale to a good home.Thanks!
626-376-0078
dweezil22
NE For Sale/Wanted
12
09-09-2015 10:50 AM
akagc
08-11-2015 07:07 PM
MolecularConcept
08-05-2015 04:43 PM
