{ FS } 2004 Brilliant Black 6MT Grand Touring **BHR ignition, mounts, Sohn, poly bushings**
Year: 2004
Make: Mazda
Model: RX-8
Price: $7499
Mileage: 110000
Color: Brilliant Black
Pros:
- New front brake pads + rotors.
- Fresh alignment. Have settings sheet.
- Water system gone through ~10k ago. New pump, thermostat & Racing Beat silicon hoses.
- BHR coil pack, MSD wires and NGK plugs done 5k miles ago.
- BHR motor mounts (orange stiffness).
- Replaced air pump ~$400 part.
- Replaced metering oil pump ~$1200 part.
- Sohn MOP adapter (search here or Google for what this does, it's one of the best things you can do for the life of the motor). Purchaser gets my supply of Idemitsu premix.
- Belts done ~10k mi ago.
- Energy suspension front poly bushings (black). Have rear set, not installed. The rear kit comes with the car.
- Michelin Pilot Super Sport tires with ~60% tread left.
- Other small fixes (fixing rattles, fixing tail light gaskets, sun visors, replacing plastic rivets, etc).
Cons:
- Mild dings in the rear fender flares (one each side). Couple small door dings. Couple scrapes on the bumpers. Rock chips from 10 years of driving. Honestly the car hides it pretty well and it still looks good.
- Small hole worn in the outer shifter boot but it's not very noticeable, again.
- Very slight water damage to the passenger brake light reflector from water sitting inside for a while (before I bought it). Brake lights are all sealed up now with RTV and weather stripping.
Send me a PM if interested! This is a good car to buy if you want a reliable and well taken care of machine that you don't have to worry about keeping the exterior pristine. Selling because I want a Miata!
dweezil22
NE For Sale/Wanted
12
09-09-2015 10:50 AM
akagc
08-11-2015 07:07 PM
