{ FS } Hinson LSX V8 swap kit brand new
on
SOLD. Hinson LSX V8 swap kit brand new (price reduced)
Category: Drivetrain
Price: $2800
Here is what comes with the kit:
HSC RX8 LSX Mounting Equipment Kit
HSC RX8 Long Tube Headers Stainless Steel, 1.875, 3' Collectors with integrated merge spike
HSC RX8 Radiator/Cooling System - Single Fan
HSC RX8 Steel Driveshaft
HSC RX8 V8 Master Cylinder (Modified)
Banjo Bolt, Banjo Fitting, & Washers
HSC New SS Clutch Line LS1
HSC RX8 Sway Bar Mounts
MGW FBody Short Throw Shifter - 12mm x 1.75' Handle
HSC RX8 Stainless Steel 3" Ypipe (allows you to connect long tubes to stock exhaust)
HSC RX8 Tach Kit - Includes Machined Balancer, CPS Bracket, and balancer bolt
Kit is located in Tampa,FL.
Contact Dan at 719-291-6388
******Update. Sold the Long tube headers and Y pipe. New price is $2800 obo. plus $150 for shipping.
on
I can take $1500 off the price if someone wants the kit without the long tubes and y pipe.
Can take $500 off the price if the tach kit is not wanted.
Thanks.
Thanks.
on
Here are more details on what is included in the mounting kit:
Urethane Engine Mounts
Billet CNC Engine Stands
New Tie Rod Ends
Steering Adapter
Steering Rack Mounts
Transmission Brace and weld on mount plates
Torque Arm (Differential Support) & Mount
price is obo. thanks guys
New Tie Rod Ends
Steering Adapter
on
As per a request here is the price for each item from my hinson invoice.
$1185 HSC RX8 LSX Mounting Equipment Kit
$565 HSC RX8 Radiator/Cooling System - Single Fan
$275 HSC RX8 Steel Driveshaft
$95 HSC RX8 V8 Master Cylinder (Modified)
$13 Banjo Bolt, Banjo Fitting, & Washers
$87 HSC New SS Clutch Line LS1
$150 HSC RX8 Sway Bar Mounts
$235 MGW FBody Short Throw Shifter - 12mm x 1.75' Handle
$491 HSC RX8 Tach Kit - Includes Machined Balancer, CPS Bracket, and balancer bolt
Total is just under $3100.
SEANMAC777
10-30-2013 10:41 AM
