{ FS } S2 4.770 Rear End Pumpkin Ring and Pinion Differential
Old 09-02-2014, 07:25 PM
CustomMSP's Avatar
Category: Drivetrain
Location (US State/Canada/Int): NJ
Sold.
Attached Thumbnails S2 4.770 Rear End Pumpkin Ring and Pinion Differential-20140902_152440.jpg
Old 09-02-2014, 10:33 PM
Supīdo-kyō's Avatar
Do you know how much it would cost to have seals and bearings replaced??
also was its effect on gas milage pretty noticeable
Old 09-02-2014, 11:43 PM
Yayforaddison's Avatar
So. Tempting.
Old 09-03-2014, 08:15 AM
antonio8's Avatar
Definitely tempting
Old 09-03-2014, 09:26 AM
CustomMSP's Avatar
Unfortunately the labor costs can vary. The seals / bearings / shims (if needed) will cost about $100 from Mazda. The labor is probably about 100-150, because it might take a few tries to achieve the proper backlash.
Regarding the mileage, I wouldn't know as this came out of my stock S2 which averages about 240 miles / tank.
Old 09-03-2014, 10:08 AM
I'mma firin' mah lazor!!!
Stray's Avatar
PM'd
New Yorker
40
03-22-2022 06:01 AM
ax75f92
08-18-2020 12:05 AM
ColeParkerrr
09-15-2015 07:30 PM
reni04
08-21-2015 01:33 PM
Bill_Monteith
08-18-2015 07:11 AM
Quick Reply: { FS } S2 4.770 Rear End Pumpkin Ring and Pinion Differential
