{SOLD} Tokico D-Spec, with Adjuster Cables
Category: Steering & Suspension
Price: $275
Springs Sold.
Dampers SOLD
Used, Tokico D-Spec Adjustable Rate Dampers (Shocks), set of 4, adjuster cables for rears. New $700. Asking $275 plus shipping. It was great to drive to the track in street mode (5 front and 6 rear) twist the ***** (3 front and 4 rear), then go soft for the ride home. I replaced them with Coil Overs for more spring rate.
Pictures Moved Here: https://plus.google.com/102890031170...ts/N3yHRnHkJ4J
PM me with zipcode for shipping quote.
Installed in July 2010, About 55,000 miles on them. A few dozen track events and highway driving make up the miles. My commute is straight back roads and highways.
I can get pictures. They are boxed at this time. They looks like D-Specs with some chips in the paint around the bottom. The shafts are clean and scratch free. I have all 4 caps as well. It is raining now, when it stops, and I can get decent light, I will get you pictures. Right now any pictures would suck.
The split price will likely be $350 / $100.
Mike
Mike
Dspec Pictures
High def pictures are not compatible with the upload limits.
I really think that you can get to pictures by clicking this link
they should be shared with public
There should be 7 pictures.
At Trev,
FWIW, I looked hard at the S when I bought these. The difference is about 28 lbs per inch in the front, and 16 lbs per inch in the rear. I went with the H because I wanted to keep the factory rear height and just lower the front enough to kill the gap over the tires. I ended up with even gaps, a nice rake to the car, and better MPG. I stuck a spring rubber in the rear to firm it up and really liked it last time at the track.
I added a picture from the track to the album.
At Trev,
Jelliott5384
10-26-2016 05:15 PM
garethleeds
Europe For Sale/Wanted
11-19-2015 06:32 AM
09-30-2015 01:53 PM
