{ FS } 4 brake rotors, used
Old 06-19-2015, 04:35 PM
Primordial Soup
ktec's Avatar
CA Sold
Category: Brakes
Price: $50
sold
Old 06-20-2015, 04:07 PM
pcs
pcs's Avatar
whats the surface thickness?
Old 06-21-2015, 07:44 PM
Primordial Soup
ktec's Avatar
About 23.5mm on the front rotors
About 18mm on the rears
I found the OEM pads too I can throw in the deal
Old 06-29-2015, 12:12 PM
Primordial Soup
ktec's Avatar
Bump
Old 06-29-2015, 02:33 PM
Smoke45's Avatar
Not to ruin your sale, but to save some headaches I'll share this information.
The minimum thickness for the front rotor is 22 mm & 16 mm for the rear.
At my local auto shop (O'Reilly's) they are required to take off 3mm when they turn the rotors. It may be different elsewhere. If the rotors are below the minimum thickness after turning they can not give them back to you. So you'd end up paying $60ish for turning and then have your rotors taken from you.
At the mentioned thicknesses you'd be likely to lose the rotors if you had them turned.
Old 07-10-2015, 11:51 AM
Primordial Soup
ktec's Avatar
Thank you for the fact, I am aware of the minimum thicknesses (they are stamped on the rotors).
You are assuming these NEED to be turned. A light sanding and scuffing should suffice for these.
For $50 for 4 rotors and pads, these are more for someone to get driving for cheap.
Old 07-10-2015, 11:45 PM
wankelingoff's Avatar
Where are you located? These are OEM rotors, correct?
Old 07-12-2015, 11:58 PM
Primordial Soup
ktec's Avatar
Glendale or Downtown LA; yes oem rotors.
Old 07-15-2015, 01:24 PM
I'll take them.
Old 07-25-2015, 09:03 PM
Primordial Soup
ktec's Avatar
02-20-2019 05:16 PM
hufflepuff
05-30-2016 10:45 AM
jamespond24
12-01-2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
10-14-2015 12:29 PM
D13
10-01-2015 07:55 AM
Quick Reply: { FS } 4 brake rotors, used
