{ FS } 2004 Mazda RX8.
on
2004 Mazda RX8.
Year: 2004
Make: Mazda
Model: RX-8
Price: $7000
Mileage: 96702
Color: Velocity Red
2004 Mazda RX8 4 port automatic
96,702 miles.
engine was replaced at around 40K miles
fuel tank heat shield replaced when recall was issued.
passenger side LCA replaced when recall was issued.
parts replaced in past 2 months:
K&N air filter and throttle body and MAF both cleaned
intake manifold to engine gasket and both of the int. man. rubber gaskets and throttle body gasket replaced.
new Duralast battery and battery terminals
engine flushed and new Mobil11 synthetic oil, and K&N oil filter installed
radiator flush with Prestone radiator flush and new Prestone coolant and distilled water
new coolant tank with sensor
new thermostat and gasket
new Garageline header, new upstream O2 sensor,
new genuine exh. manifold gasket and new locknuts,
new Magnaflow cat. converter with all new nuts and bolts,
new TurboXS exhaust with all new hardware and gaskets.
new rear bumper exhaust finishers ( covers that go over the rear bumper around exhaust tips)
trans flush with Seafoam Transtune
new AT filter, pan gasket, and AT fluid.
new crank position sensor
new belts and tensioner pulley
new fuel pump and fuel pump O ring gasket
new ignition coils, spark plugs, plug wires
new brake calipers, rotors, pads, slider bolts, anti-rattle shims, rotor screws and brake fluid flush and performance brake fluid. both front and rear brakes completely replaced.
headlight lens restoration
new front bumper lower air dam and hardware with Rotary 13B1 polished aluminum rotor emblem.
new Secondary Shutter valve, gasket, and bolts.
new electronic power steering short harness
that's everything so far. I will add more pics tomorrow. If anyone has any questions about the car, please let me know. remember the price is not firm at all. It is OBO. It is located in Palm Coast, FL. pm me for a number please. My name is Ryan.
on
yep. I had a nice 6 speed a few years ago, but ended up taking all the goodies off and trading it in since it seemed to be too nice to buy the way it was. This was a friend of mine's car that I fixed for them and they ended up selling it to a friend of theirs.
gwilliams6
General Automotive
10
10-18-2015 09:36 PM
S54Kaleb
10-06-2015 08:41 PM
Redfusion3
10-04-2015 09:08 PM
