RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } 2005 Mazda RX-8 - C-street autocross package
Old 07-26-2016 | 07:16 AM
jrose29's Avatar
2005 Mazda RX-8 - C-street autocross package - SOLDSOLDSOLD
Year: 2005
Make: Mazda
Model: RX-8
Price: $8500
Mileage: 101500
Color: Blue
Location (US State/Canada/Int): MI
2005 Mazda RX-8
Winning Blue
6-speed
~101k miles (will increase as I drive it/auto-x)
Sport package - HID headlights, traction control, fog lights, no sunroof
Clean title
$9200 obo
Engine has about 25k miles on it, replaced with factory new block (NOT a reman) under warranty by a previous owner. It's strong and works as it should
Recent maintenance:
-clutch pedal bracket
-rear O2 sensor
-fuel pump
-radiator and hoses
-transmission and diff fluid
-coils, wires, plugs (BHR upgrade)
-rubber shift boot
Exterior is in good shape for an 05. Front bumper does have some scuffs from auto-x but still looks very good. Interior is in great shape. Has new suede shift boot and aftermarket ****.
C-street prep:
- ProParts Koni DAs built by Jeff Wong. Custom valving and degassed, with the rears converted to external adjustment at the top. DR rear rebuilt this past spring, others in great shape.($2300 new) Multiple “speedthane” bumpstops to tune with as well.
- Progress MX-5 front sway bar with 949 endlinks and harder durometer progress bushings. (Bar rates quoted from Progress - 478 lbs/in-543 lbs/in-662 lbs/in)
- Muffler shop Borla XR1 exhaust. Seriously awesome exhaust. Great on the highway and loud when you want it to be.
- Stoptech brake pad front and rear
- Green air filter
- BHR ignition coils
- Alignment - -2.0 camber up front, -1.3 rear, 0 toe all around
- weighed 2830# at Toledo pro last year (compare to frs @ 2750)
Wheels/Tires:
-4 17x8 +48 O.Z. ALLEGGERITA HLT (15.6lbs $1200 new) with 245/40-17 RE71r’s (100 runs)
-4 17x8 +45 TRmotorsports FF10 (16.6lbs) with new 245/40-17 RE71r’s ($1450 new)
-4 17x8 +45 Kosei K1-TS (~15lbs) with 235/45 Continental DW’s (~50% tread)
It’s a very balanced car in CS trim. Has no bad habits and will rotate as much as you want it to on entry if you play with the shocks. With the bumpstops it also is very neutral on throttle. I still think it can get it done in CS against the ND and twins, especially on a higher speed course. ~63mph in 2nd gear. Its also one of the cheapest ways to get into a nationally competitive car and class in solo. Easily fits 4 tires in back seats and luggage in the trunk.
Its been a fun car while I have had it and makes a great street car as well. Looking for $9200 with all 3 sets of wheels. Basically ready to go for nationals with the new set of rubber. Can negotiate price based on wheels/shocks/etc. Located in Ann Arbor, MI area but would be open to delivery at Nationals as well.
Top pax at a local (small lot)
Andrew driving it much better then I.
Recent local event
Old 07-26-2016 | 07:58 AM
Love_Hounds's Avatar
Originally Posted by jrose29
[...]Engine has about 25k miles on it, replaced with factory new block (NOT a reman) under warranty by a previous owner. It's strong and works as it should [...]
Who did the engine?
Old 07-26-2016 | 12:09 PM
jrose29's Avatar
Originally Posted by Love_Hounds
Who did the engine?
Mazda... OEM warranty claim. Should show up on carfax or dealer search
Old 07-26-2016 | 02:00 PM
NotAPreppie's Avatar
What am I doing here?
How did you get a factory new engine? They stopped building the S1 engines ages ago. IIRC, all warranty replaced engines for the last 10 years have been remans.
Old 07-26-2016 | 06:36 PM
jrose29's Avatar
I did not own the car when it was replaced. Documents from Mazda and on Carfax say new factory shortblock instead of reman. Take it for what it worth. The motor is very strong and has no signs of trouble
Old 08-23-2016 | 07:08 AM
jrose29's Avatar
Lowered asking price on package to $8500.
At this time I am also willing to part-out a few items
$800 - 17x8 +48 O.Z. ALLEGGERITA HLT (15.6lbs $1200 new) with 245/40-17 RE71r’s (100 runs)
$1150 - 4 17x8 +45 TRmotorsports FF10 (16.6lbs) with new 245/40-17 RE71r’s ($1450 new)
$1700 - ProParts Koni DAs built by Jeff Wong. Custom valving and degassed, with the rears converted to external adjustment at the top. DR rear rebuilt this past spring, others in great shape.($2300 new)
RX8 minus parts mentioned above ~ $6k obo
Old 08-31-2016 | 02:46 PM
amulu10's Avatar
Is this still available?
Old 09-19-2016 | 07:03 AM
jrose29's Avatar
car is sold
Feffman
SE RX-8 Forum
10-21-2016 07:39 AM
pistonhater
9
06-28-2016 10:19 AM
Feffman
MW RX-8 Forum
05-31-2016 06:08 AM
Midwhip
05-08-2016 11:54 PM
Inkslingerzero
09-02-2011 01:59 PM
Quick Reply: { FS } 2005 Mazda RX-8 - C-street autocross package
