RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } RX8 Track car - LS conversion $45K
Old 06-23-2017, 12:11 PM
perryrace1's Avatar
Year: 2006
Make: Mazda
Model: RX-8
Price: $45000
Mileage: 1
Color: red
Location (US State/Canada/Int): TX
No expense spared, professionally built, V8roadsters conversion components throughout. Test time only on fresh build.
Key features include:
- V8Roadsters mounting kit, steering conversion, headers
- Pro built and tuned 347 Cu/In LS race motor
o Heads
CNC ported heads
Custom CAM
Hardened push rods
Comp 918 valve springs
Wegner upgraded rocker arms
o Comp Cam
o After market rods w/ ARP
o Mahle pistons
o Dry sump system
Lingenfelter ASA single stage scavenge system
3 gallon Peterson dry sump tank
Oil coolers (2)
o Intake
102 MM FAST LSX intake
Matching ‘Big Mouth’ throttle body
- Fuel system
Aeroquip fuel pump
Aeroquip regulator
Aeroquip fuel rails
Matched injectors
Fuel Cell (22 Gallon Fuel safe pro PC122B)
- Ford 8.8 LSD rear
- T56 transmission (Built to stage 3)
- Mcleod Light weigh flywheel / clutch
- Cooling system
CNR alloy racing radiator
Oil cooler (2)
Power steering cooler
- Suspension
Stance 3 way adjustable coil overs with remote canisters
Mcleod rear heim joint suspension arms
Delrin Racing bushings through out
Progressive rear sway bar
V8R front sway bar
- Interior
Sparco Evo Plus seats
AiM Dash with GPS
Central fire suppression system with remote nozzles
New belts
Pro built road racing cage
Drivers compartment heat shielded
Freshly painted interior, engine bay and trunk
- Custom fabricated side exit exhaust with center mount muffler, and full-length heat shields
- Power steering
‘Turn one’ power steering pump
NC power steering rack (Per V8R)
- ABS brakes with active front cooling ducts
- Adjustable carbon rear wing
- 2 sets of 18x10” Enkei light weight rims
For additional details please email markperry@perryrace.com
Attached Thumbnails RX8 Track car - LS conversion K-rx8-1.jpg   RX8 Track car - LS conversion K-rx8-2.jpg   RX8 Track car - LS conversion K-rx8-3.jpg   RX8 Track car - LS conversion K-rx8-4.jpg
perryrace1 is offline
