{ FS } Rx8 13brew swap part out
Old 08-15-2017, 09:04 AM
rotoryfan1991's Avatar
Category: Engine - Power Adders
Price: $5999
Location (US State/Canada/Int): KY
REW swap kit - $9500 $5999
- Mount setup -
Rx8performance motor mount kit
Modified Rx8 oil pan
Modified Rx8 front cover
- Turbo setup -
Thick wall stainless steel manifold, fully divided runners
Twin 46mm Precision wastegates
Garrett Gt42 turbo
5" to 4" stainless steel downpipe with vband and wideband bung
4" stainless steel midpipe with vband, Large Vibrant stainless resonator and Vibrant 4" stainless flex section
Aluminum intercooler piping
Large bar and plate intercooler
Greddy R bov
Braided AN turbo oil feed line
Braided AN turbo oil drain line
Couplers / tbolt clamps etc
AN boost reference lines
Electronic boost controller with adapters
- Cooling system -
Large Koyo radiator with custom mount bracket
Mishimoto aluminum fan shroud with dual fans
Custom aluminum coolant lines
Silicone couplers
Custom rx8 thermostat housing with AN fitting welded on for heater core line
Custom heater core lines
Modified Rx8 ac compressor with custom ac lines
- Haltech Standalone ECU - $1200
Haltech PS1000 with long wire loom terminated for a 13b rew engine / Haltech fuse and relay block built in
- 13brew engine shortblock - $3999
8k miles never boosted over 3 psi
Full Bridgeport
8.5 compression rotors with 3mm apexseals
Rx8 e shaft
Dowel pinned
Oil mods
Balanced
rotoryfan1991 is offline
Old 08-15-2017, 09:12 AM
Old 08-15-2017, 09:52 PM
cweezyf's Avatar
Pm incoming!
cweezyf is offline
Old 10-12-2017, 12:27 PM
Bump everything is available, will be listing on other sites today.
Old 10-12-2017, 12:46 PM
comebackqid's Avatar
I wish that block was street ported. I would get it! You willing to part just the front cover?
comebackqid is offline
Old 10-12-2017, 03:33 PM
Unfortunately I'd like to leave the front cover on it unless I sell the block without it first. I can probably have another one modified for you if interested message me we can talk a price.
Old 10-16-2017, 04:45 PM
Old 11-10-2017, 11:07 AM
I have decided on a 3 rotor for the drift car now so i will no longer need the custom intake / haltech ecu / injectors so im willing to sell the entire swap including the custom intake manifold / RMR throttle body / ID injectors / Haltech PS 1000 ecu with fuse and relay wire harness etc..
COMPLETE turn key kit. Bolt in and have tuned.
If SERIOUSLY interested and would like to make an offer please message me.
Thanks !
Old 11-10-2017, 12:25 PM
Junior Member
Nick Ray Robardey's Avatar
PM'ed on Rx7club, no response.
Nick Ray Robardey is offline
Old 11-25-2017, 01:58 PM
TTT
Price drops!
REW swap kit - $8500
- Mount setup -
- Turbo setup -
Garrett Gt42 turbo
Greddy R bov
- Cooling system -
Silicone couplers
- 13brew engine shortblock - $4750
Full Bridgeport
Rx8 e shaft
Dowel pinned
Oil mods
Balanced
Old 12-05-2017, 11:18 AM
itsboost's Avatar
hwo much for just this?
- Mount setup -
itsboost is offline
Old 12-05-2017, 11:30 AM
still watching you able to ship to CA 93536? REW short block.
Old 12-07-2017, 11:31 AM
- Mount setup -
Messaged.
Shipping is no problem, freight to you is $297 if picked up at your local terminal.
Pallet is 250 lbs 24" x 24" x 24"
comebackqid (12-08-2017)
Old 12-11-2017, 11:04 AM
BUMP
BIG price drops again !
Swap is now under $8000..
Engine under $4000..
Crazy to me all the people doing rew swaps now and no one has jumped on this yet..
Old 12-12-2017, 09:47 PM
Ben Cole's Avatar
Why
Why you don't sell it completely with car?
I see you post separately shell.
Ben Cole is offline
Old 12-14-2017, 11:12 AM
It would take a long time to sell the complete running car due to the high price imo.
Old 08-27-2018, 03:18 PM
Bump
Will take $5999 for the full rew setup without ecu / fuel injectors !
The fabrication cost alone was more than that not including any materials or parts !
Honestly cant believe im even selling this cheap but have no use for it anymore..
Dietbudda
Rotary Swaps
31
06-25-2020 08:08 PM
Dpierce
07-02-2019 10:38 PM
sixgen3sgte
Non-Rotary Swaps
126
11-15-2010 08:06 AM
SilverHokie
RX-8 Multimedia/Photo Gallery
05-04-2009 08:28 PM
fc3s.org
51
04-14-2007 12:56 PM
Quick Reply: { FS } Rx8 13brew swap part out
