{ FS } 13b rew swap
13b rew swap
Category: Drivetrain
Price: $6500
Location (US State/Canada/Int): KY
This is a COMPLETE swap WITHOUT the REW engine block / Haltech ECU / ID Fuel injectors.
Engine
-Rx8 engine front cover modified to fit the rew block
-Rx8 oil pan cut / welded to fit motor mount
-Rx8Performace stainless motor mount
Ignition
-AEM smart ignition coils x4
-MSD spark plug wires x4
Fuel
-Walbro 485 e85 in tank pump
-modified fuel pump housing
-8 AN nylon braided fuel feed line from tank
-8 AN feed lines to fuel rails
-6 AN return line to stock fuel feed line
-Aeromotive 1000 fuel pressure regulator
-FPR gauge
-Custom fuel rails
Coolant system
-Koyo radiator meant for a skyline
-Custom mount for radiator
-Mishimoto aluminum radiator fan shroud
-Custom aluminum coolant lines
-Custom AN lines to heater core
Turbo setup
-Garrett GT42 turbo T6 large divided housing / Anti surge housing
- AN oil feed and return lines
-Custom fully divided thick Stainless steel turbo manifold
-Twin Precision wastegates
-Greddy Type R blow off valve
-Custom 5" to 4" Stainless steel downpipe with wideband bung
-Custom 4" Stainless steel midpipe
-Vibrant 4" Stainless steel flex section
-Custom aluminum turbo piping
-Vibrant intercooler
-Vibrant / Mishimoto couplers and t bolt clamps
-Wiggins style quick release clamp on throttle body to intake piping
-MAF bung welded onto intake
-Intake air temperature bung welded to intake
- AN PTFE boost vacuum lines / adapters
-Black Turbo blanket
-Turbo intake filter
Custom intake manifold
-1 off intake plenum
-Ross Machine racing velocity stacks
-Ross machine racing 90mm throttle body w/ supra tps adapter and sensor
-Vacuum ports welded to bottom
-Fuel rails mounted to top of runners
-Universal billet aluminum gas pedal
-Custom throttle cable
Misc
-Ac compressor with mounting bracket welded on
-Custom Ac lines to use the Rx8 condenser
-Custom bracket to hold Rx8 Eshaft position sensor
-Custom -10 AN oil lines to both stock oil coolers
Also includes the complete Rx8 engine bay wire harness / fuse box etc that has been modified (this will need some cleaning up cosmetically.
Salamanth
12-17-2007 06:13 PM
OneEvilRx8
17
05-07-2006 12:25 AM
