RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } Pettit Supercharged RX-8 Racecar
Old 09-18-2021, 05:00 PM
Angler of the Year
slvrstreak's Avatar
Year: 2005
Make: Mazda
Model: RX-8
Price: $12000
Mileage: 0
Color: Orange
Location (US State/Canada/Int): GA
Up for sale is my Pettit Supercharged RX-8
Please do not PM, my inbox stays full.
Call or text 478-697-2472
Details of the build below but, first some pictures:
Drivetrain/Exhaust:
- Pettit streetported race build with MANY modifications to the oil system, port cleaning, cooling jackets etc.
- Pettit Stage II supercharger with low boost pulley setup ~ 7-8 psi (high boost available)
- Tuned by Steve Kahn @ 325 rwhp conservatively
- Upgraded bypass valve--supercharger intake tube/bypass valve port has been milled
- Custom worked lower intake manifold--runners shaped, smoothed, polished, ventilated, jet air deleted with reshaped port and VDI filled in
- Enlarged throttle body--dremeled and smoothed supercharger intake
- Tubular header with 3" true merge collector to custom midpipe and 3" exit
- Series II fuel pump
- Series II transmission with syncrosaver
- Act Pro Lite flywheel and new stage 1 clutch/throw-out/pilot bearing
- MSD 8247 ignition system
- Boost-a-spark system to control voltage to the coils- (the oem system only supplies 12.1 voltage to the coils; the msd coils like 16 volts which means the coils don’t need long dwell times)
- Grounding kit
- Oil filter relocation with stainless steel lines with AN fittings
- Polyurethane filled motor mounts.
- High output starter
- Hose candy custom lines/fittings in engine bay
Cooling/Reliability:
- Mazmart water pump and thermostat
- Ron Davis oversized radiator
- Secondary radiator with its own 180 degree thermostat
- Flex-a-lite variable fan speed controller
- Extra fan on the passenger side oil cooler with console switch
- Dual overbored oil coolers from Mazmart
- Upgraded air/water intercooler with a frozen boost coolant cooler
- Relocated coolant pump
- Moroso coolant tank with custom mount
- Silicone radiator hoses with coolant temp sensor in top radiator hose
- Small fan mounted on the pcm box for extra cooling
Suspension:
- Ohlins Full Race DFV shocks revalved and matched with Swift 13kg/8kg springs
- Racing Beat front and rear sway bars with endlinks
- Mazdaspeed front strut bar with master cylinder brace
Exterior:
- Two-tone paint Brilliant Black on Competition Orange
- 18X9 Enkei RPF1s wrapped in 225/45 Kumhos
- Front splitter tied into the chassis w/ tie-rod adjustment
- Rear diffuser tied into chassis
- APR GTC-200 Carbon Fiber Wing w/ endplates and tie-rod adjustment (chassis mounted)
- Smooth underbody paneling
- Cage mounted jack points all the way around (w/ T-bar extensions)
- Louvered front quarter panels and rear quarter panels (interior) to reduce lift
- Vented hood
- Milled and vented front grille
- Carbon fiber roof straight from Speedsource…this was a GrandAm prototype and sheds 26 lbs off of the roof
- SHIELDS lexan windshield, rear window, and quarter panels (all with anti-scratch exterior coating and anti-fog interior coating)
Interior:
- Completely gutted interior (over 400lbs shed overall)
- Custom aluminum dash
- Sparco suede steering wheel with short hub and quick detach
- Sparco Evo 2 Plus seats (driver seat on sliders)
- G-Force 6-point harnesses
- Allstar Performance driver window net
- Simplified wiring harness
- Optima Red top mounted under passenger dash
- MSD 8247 coils mounted under passenger dash
- AIM MXL dash/datalogger (never installed)
Spares:
- High boost pulley setup rated for 11 PSI
- Brand new Racing Beat Performance Oil Cooler Set (simplified 3-line set)
- Brand new fuel cell setup…JEGS 15gal aluminum fuel cell
- JEGS electric fuel pump, billet fuel pressure regulator, and comp fuel filter
- Performance stainless braided lines and all AN fittings needed
- Stock dash cluster (can be plugged right back in if preferred)
- Cobb Accessport for datalogging, DIY, or remote tuning
- Snow Performance Boost Cooler water methanol dual nozzle MAF driven system with 1 gallon tank and pump
- LoTek gauge pod with Prosport water temp, Prosport oil temp, and Prosport mechanical vacuum/boost gauge
- Racing Beat gauge pod with Prosport oil pressure and air/water intercooler temp gauges
- Extra RPF1 wheel (has a dent but holds air)
The bad:
The car has not been sorted in its current configuration. Latest updates are the aero, Ohlins ($3K), and removal of the stock dash/gauges for an AIM system (new/never installed $3K). Unfortunately, the builder was not comfortable wiring up the datalogger and I have no interest in spending any more on this project as I have other cars. Before this, the car was a very capable track weapon with consistent 1:37s at Road Atlanta on street tires. With proper suspension and aero adjustments it would be even faster now with a capable driver. Besides installing the datalogger, I suspect it will need a proper shakedown before getting back into action full steam.
I have well over $30k in this build but, as stated before, I don’t not have the time, space, or desire to carry it any further. If you are looking for a rotary-powered rocket ship that is 90% there at 50% of the cost; my loss is your gain.
slvrstreak is offline
Old 09-18-2021, 05:39 PM
The Blue Blur
sonicsdaman's Avatar
Received 3,668 Likes on 2,622 Posts
Oh dang its slvr
bump for a good dood
sonicsdaman is offline
Old 09-19-2021, 07:12 AM
RyanAlexander's Avatar
Really nice car!
RyanAlexander is offline
Old 09-20-2021, 07:21 PM
olddragger's Avatar
The memories! This is my old car everyone. Pettit did place the larger apex seals in the engine also. The supercharger an intake manifold has a lot of work in the channels ..smoothing things out. When Steve Kahn tuned it he was on the phone with cam ( Pettit racing) and they wanted to take it higher, but I put the brakes on that. Then it was street driven daily and I wanted an conservative tune.
The series 2 trans paired with the series one diff gives you a different gear ratio. At road Atlanta I mostly used two gears, 3nd and 4th with a short upshift to 5th on that long back straight. I shifted at a little over 7.5k rpm. I didn’t push it. The engine should have great compression. Silver bought it from me and took it to the next level. I wasn’t tracking anymore because I was starting to go too fast without more safety equipment and I didn’t want to get into that.
You could not pick a better buyer! He will be 110% transparent and is totally honest. Levi is one cool guy. Someone is going to be a happy rotorhead. This is kind of a rare bird car.
By the way, the cage is reported to be almost a work of art.
olddragger is offline
The following 3 users liked this post by olddragger:
200.mph (09-23-2021), Fickert (11-10-2021), Jedi54 (11-22-2021)
Old 09-23-2021, 08:54 AM
Angler of the Year
slvrstreak's Avatar
Originally Posted by sonicsdaman
Oh dang its slvr
What's up sonic? Been a while man!
Originally Posted by RyanAlexander
Really nice car!
Thank you sir!
Thanks Denny. With a little work and sorting someone will have an amazing track weapon for the price!
I washed the wheels and changed the tie rods on the splitter and wing today just to get a more adjustable AOA. They are black now so they match for you OCD people that called me out on it haha
Old 09-23-2021, 09:38 AM
FULLY SEMI AUTOMATIC
200.mph's Avatar
Received 2,382 Likes on 2,010 Posts
good luck with sale brown streak, hope all is well buddy. as soon as i saw the listing i figured it was dennys old car
200.mph is offline
Old 09-28-2021, 04:08 PM
OfficerFarva's Avatar
Nice build! Sent you a text. Definitely interested.
OfficerFarva is offline
Old 11-08-2021, 04:44 PM
Angler of the Year
slvrstreak's Avatar
Still for sale. Plenty of interest but, no solid takers yet
Videos of cold start and red line upon request. Site didn't want to accept MP4 files
Old 11-10-2021, 01:10 PM
Wanker
RastaRx-8's Avatar
"Videos of cold start and red line upon request"
hopefully not at the same time! :P ill trade you a shinka copper red shell for it !
RastaRx-8 is offline
Old 11-22-2021, 06:21 AM
Angler of the Year
slvrstreak's Avatar
Definitely not lol
Old 11-22-2021, 10:26 AM
Angler of the Year
slvrstreak's Avatar
Update!!!
Price drop at $12,000 FIRM
Well over 30k invested not including labor. Runs perfectly fine with 19" of vacuum.
Dash needs to be installed or the original reconnected. (Cobb, AIM system, and original dash included)
Race it or part-it and profit. Doesn't matter to me. Plenty of high dollar parts:
- Pettit upgraded Supercharger
- Fully race spec engine build by Pettit
- APR GTC-200
- GrandAm CF roof
- New Ohlins Full Race coilovers w/ Swift springs
- New $3k AiM MXL system datalogger programed for the RX-8 (controller, pyrometers, and all connectors)
Please do not PM me or ask questions here. My inbox stays full and this site is blocked from my work computer.
Call or text directly (478) 697-2472. Have plenty of videos or if you need something specific. Plenty of interest last time but, only posting the lower price here. I do not have time to deal with the idiots on Facebook again.
200.mph (11-22-2021)
Old 11-22-2021, 01:11 PM
Received 2,716 Likes on 1,957 Posts
bump for a good guy selling a car with plenty of quality work done to it.
knowing this was OD's and now SS's, you know you're buying something pretty cool.
GLWS, hope it goes to a good home
Jedi54 is offline
Old 11-22-2021, 01:15 PM
200.mph's Avatar
another bump for a good guy.
200.mph is offline
Old 11-28-2021, 04:07 PM
Angler of the Year
slvrstreak's Avatar
Thanks guys
Jedi54 (11-28-2021)
Old 12-28-2021, 04:01 PM
Angler of the Year
slvrstreak's Avatar
Alright guys didn't think it would come to this but the wife wants her parking spot back.
-----------------------$10,000 FIRM-----------------------
This thing runs like a top. Drive it, flip it, part it...doesn't matter to me.
The high dollar items (supercharger, engine build, roof, seats, wing, brand new Ohlins, and AiM MXL) alone are worth much more than that.
Come and get it!
Old 03-14-2022, 03:00 PM
Spinning Dorito Junkie
Redshift's Avatar
It's been almost 3 months since last post. Does this happen to still be available?
Redshift is offline
Old 04-14-2022, 11:17 AM
Mazdarxforlife's Avatar
Interested
Interested how do I reach you ?
Mazdarxforlife is offline
Old 04-14-2022, 11:41 AM
200.mph's Avatar
Drivetrain/Exhaust:
- Grounding kit
Suspension:
Exterior:
- Vented hood
Interior:
Spares:
The bad:
his # is in the first post, i made it bold for ya. btw the seller is a great guy, buy with conifidence
200.mph is offline
Old 04-14-2022, 08:32 PM
No respecter of malarkey
Received 2,044 Likes on 1,666 Posts
except you buried it in a sea of text copying the full novel length post with it, try this instead:
TeamRX8 is offline
Old 04-14-2022, 08:56 PM
how was it buried, its literally the 3rd line in his post.
well, guess he gets a free bump out of all this.
Jedi54 is offline
Old 04-15-2022, 08:43 AM
Angler of the Year
slvrstreak's Avatar
Sorry guys, should have updated. I sold immediately after the price drop.
Thanks everybody! Hope the new owner in California enjoys it!
The following 2 users liked this post by slvrstreak:
200.mph (04-15-2022), Jedi54 (04-15-2022)
Old 04-15-2022, 10:14 AM
assuming he reads through from the beginning rather than going directly to the actual reply at the bottom and then skimming up from there trying to find it, but I’m just kind of stupid that way …
but wrt the thread topic, congrats on the sale
TeamRX8 is offline
Old 04-15-2022, 10:19 AM
Congrats to the new owner.
Wonder if we'll see this beast at the track at SevenStock.
*thread closed*
Jedi54 is offline
palf138
08-09-2014 03:42 PM
soccercheong
Far East/Asia
03-31-2008 03:23 AM
babohan
12-06-2007 04:44 PM
Quick Reply: { FS } Pettit Supercharged RX-8 Racecar
