{WTB} Master Cylinder Hard Lines to DSC
Old 11-03-2022, 08:40 AM
onlytrueromeo's Avatar
Category: Brakes
Price: $50
Location (US State/Canada/Int): NY
I just bought a 2004 M/T GT and it has the early model year master cylinder. I want to swap this for one of the 2006+ ones, and to do that need the hard lines. I tried to order from Mazda and they canceled the order, so I don't believe there are any more in stock.
Does anyone have one for a later 2006 thru 2008? Part numbers (I believe) are:
FE0343250B
FE0343260C
43-250 & 43-260
onlytrueromeo is offline
Old 11-04-2022, 06:51 PM
Received 2,077 Likes on 1,693 Posts
the problem is a lot of salvage yards just snip through the brake lines to take the MC and ABS module off
the other thing to be aware of is the threaded connections, positions, and routings are all different between the DSC and non-DSC ABS modules. So you need the lines from a vehicle with the same ABS module as yours. The vast majority are for the ABS with DSC traction control. Which is in your favor because being a GT it most likely has DSC.
honestly don’t understand why you want to do that though; the early MC has a bleed screw to help get air out and it was eliminated on the later ones.
TeamRX8 is offline
Old 11-05-2022, 11:24 AM
spectre6000's Avatar
Get a tubing bender, flare tool, and some tubing/ends. Making hard hydraulic lines is one of those tasks that seems difficult and daunting, but then you get into it, and it's stupid easy.
spectre6000 is offline
Old 11-09-2022, 08:21 AM
Yep I knew most of that except the bleed screw. Interesting. The reason I was planning to swap was because the mazda dealer the previous owner brought it to said it needed it. It had mushy brakes and wasn't stopping well apparently. I picked it up anyway and drove it home 900 miles and it stopped fine but wasn't as firm as I'd like.
The pedal does not have as firm a feel as my other one (doesn't engage until halfway pressed) and the oem brakes have 15k miles on them. They are rubber lines vs. the ss ones on my shinka.
I supposed I could try upgrading/replacing the rubber lines and a full ATE flush. Was planning to do this with the MC swap. It was extremely difficult getting Info from the mazda dealer so no idea if they actually bled the brakes but the previous owner said they were better after he got it back. Still not the pedal feel I expected though.
The replacement ones for late 2005 on are much more ubiquitous.
Old 11-09-2022, 08:25 AM
Honestly I went down the rabbit hole last night. I expected it to be more difficult for sure. Tools cost more than I want for this but it's definitely something to consider!
Old 11-09-2022, 10:38 AM
Wanker
RastaRx-8's Avatar
i think i already replied on facebook but i have these if you need em
RastaRx-8 is offline
Old 11-09-2022, 11:02 AM
PM sent - probably missed it. Got lots of notifications and lots of spam pms
Old 11-09-2022, 02:35 PM
Benders are cheap, and FLAPSes will often rent you the flare tools for free. They also carry straight lines already flared with fittings on them. Know what kind of fittings/flares you need, figure out the length, and they'll often let you in the back to find one that's the right length, or at least within a reasonable margin of error. It's been a while since I've bought either, but I imagine you could get in and out in under $20 and an afternoon.
Old 11-09-2022, 05:40 PM
sounds like you’re covered, but anyone who’s looking to make their own hard lines should consider “cunifer” material (combination of copper and nickel):
https://cunifer.com/#jump
TeamRX8 is offline
petros_rx7
11-28-2022 02:59 PM
bueshy
04-09-2014 11:13 AM
sauceyI986
10-24-2011 12:21 PM
terrypk1
10-27-2009 05:03 PM
cas2themoe
05-04-2009 07:40 PM
Quick Reply: {WTB} Master Cylinder Hard Lines to DSC
