RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } FS: 2005 BB Turbo RX8 GT / Single Owner / Memphis, TN
Old 03-04-2023, 12:32 PM
jcbrx8's Avatar
TN FS: 2005 BB Turbo RX8 GT / Single Owner / Memphis, TN
Year: 2005
Make: Mazda
Model: RX-8
Price: $5000
Mileage: 171000
Color: black
Location (US State/Canada/Int): TN
For sale is my single owner 2005 RX8 GT with the complete RX8 Performance turbo kit installed. It has loss of compression on the rear rotor, and will require an engine replacement. It has been garaged at work and home since purchase and has no rust. With an engine replacement and all the goodies listed below she is capable of M/E VD: ~400 wHP, ~265 lbft @ 59*F. You won't find a cleaner turbo RX8 deal: drop a new engine and she's ready to roll.
See my turbo install thread for a complete history of additions, installations, and performance including MANY more pics: "Curt’s Gr8t 8 Turbo Build"
https://www.rx8club.com/series-i-maj...-build-268497/
  • RX8Performance turbo kit installed
    • Precision Turbo CEA Billet 5862spdual ball ceramic bearing turbo. V-band in and out, .82 A/R.
    • Precision Turbo 46 mm wastegate and spring kit allowing 17 different boost level combinations.
    • Tig Welded 11 Gauge 100% Stainless Steel manifold
    • Tig Welded 3 inch Stainless Steel downpipe with v-band wastegate port
    • Bead rolled 6061 Aluminum charge tubes
    • Synapse Blow-Off valve with recirculation fitting, hose and clamps
    • Large Bar and plate front mount Intercooler (12" Sept. 2018 - May 2021, 8" May 2021 - present)
    • Adjustable Intercooler mount to accommodate aftermarket bumper covers
    • High Quality Reinforced Silicone Couplers
    • Stainless Steel T-Bolt Clamps
    • 3.5 inch Cold Air intake with MAF Air Straighter
    • Passengers side motor mount bracket and mounting hardware
    • Braided stainless steel oil feed and return lines with hardware
  • Aux.
    • BC Racing BR Series Coilovers (installed July '20)
    • Borla exhaust
    • BHR de-catted midpipe w/ resonator
    • RX8P 72mm dual-pass aluminum radiator
    • Mitsubishi N3R3-18-400 starter
    • DW200 255 lph fuel pump
    • Rex D585 ignition coil upgrade kit
    • RX8P high capacity oil pan
    • Higher pressure oil regulator kit
    • Flex-a-lite 420 low profile fan
    • Battery reloc to trunk w/ breaker kill switch
    • L: NGK R6725-9s (aka NGK 6448 / 7420-9), T:6725-10s
    • Yellow (P1: Y (476) / Sec: UN-Y (850) / P2: UN-Y (850) injectors
    • oil filter relocation kit
Monitor, Tuning & Control:
  • Greddy Profec B Spec 2 EBC
  • AEM 30-4900 WB failsafe gauge, AFR & boost
  • Prosport IAT gauge
  • Prosport coolant temp gauge
  • Prosport oil temp gauge
  • Prosport fuel pressure gauge
  • M/E & Tactrix 2.0 MAF tune
Performance: M/E VD: ~400 wHP, ~265 lbft @ 59*F.
New tires all around: Continental Control Contact Sport SRS+ (~6k miles driven, 50k mi warranty)
Additional Negotiable Items:
Precision Turbo CEA Billet 6266sp (in addition to the Precision Turbo CEA Billet5862sp installed)
Original covered spare tire
OEM exhaust manifold
Engine hoist
12" Intercooler (in addition to the 8" IC installed)
Exterior 1
Exterior 2
Engine bay / hood vents / Garaged
Interior 1: Dash & Gauges - (boost controller in ashtray)
Performance via Mazda Edit Virtual Dyno
Current tire tread: Continental Control Contact Sport SRS+
jcbrx8 is offline
Trianglechips (07-23-2023)
Old 07-07-2023, 10:05 PM
jcbrx8's Avatar
Bump. Price reduction... for car w/ many extras and complete RX8 Performance turbo kit.
jcbrx8 is offline
Old 07-23-2023, 01:50 PM
Trianglechips's Avatar
Hey ! PM Sent !
Trianglechips is offline
Old 07-23-2023, 09:07 PM
jcbrx8's Avatar
Sold.
Admins - Please close thread.
Thanks, Curt
jcbrx8 is offline
Old 07-28-2023, 02:37 AM
comebackqid's Avatar
how much did this end up selling for?
comebackqid is offline
jcbrx8
1086
03-04-2023 09:49 AM
Riaan
34
06-07-2011 05:27 PM
Quick Reply: { FS } FS: 2005 BB Turbo RX8 GT / Single Owner / Memphis, TN
