{ FS } Large parts/package deal
on
Price: $6500
Location (US State/Canada/Int): NC
These are for pick up in Eastern NC.
One complete engine and trans, engine ran strong when removed. I do not have comp numbers.
One engine ecm flashed by Racing Beat (race tune) two keys
One roll bar/ cage for weld in. Main roll hoop and rear extensions
One complete front suspension. A arms upper(Mazda Motorsports offset bushings) and lower A arms hubs brakes etc. Brake pads are Hawk ht14. Rotors are in great shape...recently replaced All brake lines front and rear are steel braided.
One complete rear frame with diff etc. As a complete drop out. Brake pads are Hawk Blue
Rear diff 5.12 Mazda Motorsports set up by Speedsource
Speedsource race front sway bar with end links
JIC adjustable coilovers I will find my notes and report on the spring rates.
5 Kosei K1ts 17x8 +45 These are extremely light weigh and hard to find in 17x8
4 Enkei 17x9 +45
2 rotor housings in excellent shape
Complete steering rack
One Dash instrument pod
Both rear doors (gutted)
One deck lid (has holes for MS wing)
Complete brake master cylinder with reservoir lines and ABS pump
One NEW ACT (Mazdaspeed)light weight flywheel with new correct counterbalance
One NEW ACT 4 puck sprung clutch
I am sure there are more parts that I will find and include.
List above will be updated as I run across parts.
on
You are entitled to your opinion. Hell a low ball price on the wheels alone would be 2K..check ebay
Housings would be 800 etc
I want to sell it all as a unit...but if I part it out it'll take more time but most likely get more than the asking. I have too many irons in the fire right now to part it out.
Thanks for the bump
Thanks for the bump
on
Found another Kosei wheel that goes.
Also full stock exhaust..gutted car with Borla stainless muffler
Add one aluminum race seat Kirkey with seat cover
One 10 lb fire bottle suppression system
sburkett
04-23-2009 06:00 PM
