{ FS } 2009 rx8 r3 black
2009 rx8 r3 black
Year: 2009
Make: Mazda
Model: RX-8
Price: $12000
Mileage: 93217
Color: BLACK
Location (US State/Canada/Int): NY
1. Enkei TSV 18x9.5 +38, PS4S 265/35R18 new condition
2. BHR Catted Resonated Mid pipe
3. BHR Coilpacks + wires
4. Racing Beat Exhaust, Airpump Delete
5. Racing Beat revi Coldair Intake
6. Racing Beat F & R Sway Bars +Links
7. AEM Oil pressure, Temp Sensor, iBank Gauges
8. Odula Carbon Front Lip
9. New LCA, new Rear Cambee Arms
10. Koyo 48mm Radiator
11. RX8 Performance Upgraded Oil Coolers
12. New Battery
13. Powerstop Remain New Calipers with Carbotech AX6 in almost new condition
14. Apple carplay compatible Headunit
15. Mazdatrix Premix Box
Issues, see pictures
1. Left front headlamp has tint residual, will remove before sell.
2. Right rear wheel small chip
3. All AC components functional as operated as in modes switching but display screen does not read (Display has been change)
4. Hazardous button broken
5. Exhaust shroud warped from heat.
6. Passenger side airbag cover cracked
7.I did not have a chance to put in the oil pressure so the AEM sensor can only read oil pressure so far, it’s up to the new owner to see where they want to hook up the oil temperature sensor, comes with full kit.
8. Some regular wear on the Recaro Seats, hoops missing but I got new ones but never had a chance to install them.
Compression Numbers will be provided in a few days, I work at a shop so end of a month is kind of busy and I have not been able to access my storage to grab my compression tester. I want the put the post up to get it going first. Noted this engine has about 40k or less mileage,
A brief information on this car:
I purchase this car about 2 years ago at least, previous owner has a reman tranny put in by the dealership 08/20, have invoice. Also a reman engine done TWICE at the same said dealership due to they fucked up with bearing failure and only changed the engine but NOTHING else, hence when I got the car I got low oil pressure on the brand new engine and some blocked oil cooler. So after I got it and I diagnosed the problem i said f*** it so I sent it to IRP getting rebuild but due to their recent scandals thank god I only just got it back recently, I have a 2nd RX8 R3 with 38k miles as some of you may know so after I got this one back I took all the mods out(ohlins ans etc.) Swap the built ported motor from IRP and return this car to stock as much as possible. I don’t need 2 RX8s, I don’t want 2 RX8 I’m looking for a daily. Hence selling the car.
I throw a a price to test the water, so please DM me for offer.
TINT RESIDUAL
CHIP ON RIGHT REAR WHEEL
HAZARUS BUTTON MISSING
DISPLAY INOP - AC FULLY FUNCTIONAL
fastlaneracing
12
08-29-2008 02:35 AM
