{ FS } Custom long-stroke bilstein-based coilovers
Old 04-06-2024, 08:27 PM
hufflepuff's Avatar
Category: Steering & Suspension
Price: $950
Location (US State/Canada/Int): VA
SOLD SOLD SOLD
For sale is a custom coilover suspension setup based off bilstein B6 dampers. The setup performs well at autocross and track, and even rides respectably on the street as well. This setup is different from just about any other coilovers in that it retains 100% of the stock (OEM) travel, but also allows for a wide range of ride height adjustment via threaded body conversion. I will include the parts list and a few videos of this suspension on my car. you can go low for cheaper, but you won't retain the gigantic bump and droop travel that the stock RX-8 is well known for. I can't think of any common aftermarket kit that allows this amount of lowering with full droop, which helps the tires remain in contact with road under dynamic situations.
Here is a parts list and what it would cost to re-create (not that you would from scratch!):
- Bilstein B6 dampers w/ trimmed MCU bumpstops: $616 @ TireRack
- Allstar aluminum coilover sleeves and perches: $150 @ Summit Racing
- Ohlins 8k, 8", 2.5" diameter front springs: $170 @ Ohlins
- Ohlins 5k, 8", 70-100mm taper diameter rear springs: $190 @ 3dmmotorsport
- Ohlins front spherical top hats: $488
- HKS front tender springs & spacers: $54 @ Armageddon Turbo & Performance
- Eibach rear tender springs & spacers: $185 @ Armageddon Turbo & Performance
- Custom delrin rear spring perch adapters: $57 @ Ebay Motors
- JOE-33500 Adjuster wrench (for ride height): $40 @ Summit Racing
- Plus OEM rear top hats...
TOTAL: $1,950
Old 04-12-2024, 10:04 AM
No respecter of malarkey
Received 2,040 Likes on 1,663 Posts
very nice setup, bump
Old 04-13-2024, 01:15 PM
Grown up kid
Dodo23's Avatar
Pm’d
Check your pm
Old 04-23-2024, 06:46 AM
hufflepuff's Avatar
Sold sold sold
hufflepuff
RX-8 Racing
10-31-2023 10:04 AM
Lvis
06-13-2013 08:52 PM
LionZoo
04-09-2013 03:52 PM
LionZoo
02-20-2013 12:13 PM
Highway8
9
05-11-2012 05:23 AM
Quick Reply: { FS } Custom long-stroke bilstein-based coilovers
